Guest Lightnen Posted August 18, 2008 Share #1 Posted August 18, 2008 Hi there peoples: I've read here that the road king mufflers are a resonable good choice of muffler to get a better sound from the RSV. Now I am wondering if the H.D.'s FLH would be the same or are these too big for the RSV's. Any help would be greatly appriciated.. Lightnen Link to comment Share on other sites More sharing options...
Squidley Posted August 18, 2008 Share #2 Posted August 18, 2008 The thing with the R/K mufflers is how they hook up onto the RSV. I'm not sure on the letter configuration of the H/D's but it seems to me that you can only use pipes off a bagger with opposing side dual exhaust. I know it's probably not the answer you were looking for, but it would be some additional info anywho Link to comment Share on other sites More sharing options...
jrcain32 Posted August 18, 2008 Share #3 Posted August 18, 2008 The slip-ons I have came off an Ultra Classic, according to the guy I bought them from. I don't think it matters as long as they don't have a cat-converter. The size should match the RSV. Link to comment Share on other sites More sharing options...
hilliss Posted August 18, 2008 Share #4 Posted August 18, 2008 FLH mufflers are the same and will work just fine. Check your part numbers to make sure you are getting non catalyst mufflers. You will need Squidleys mounting plates for a good mount, and some clamps. I have run these on two of my Ventures now... they are a great deal and give you a nice deeper sound, without extra noise. Link to comment Share on other sites More sharing options...
big mike Posted August 18, 2008 Share #5 Posted August 18, 2008 FLH mufflers are the same and will work just fine. Check your part numbers to make sure you are getting non catalyst mufflers. You will need Squidleys mounting plates for a good mount, and some clamps. I have run these on two of my Ventures now... they are a great deal and give you a nice deeper sound, without extra noise. If you do get a set with cat's you can break them up and remove them. It is just an extra step and a little more work, but definitly worth it for that nice deep rumble. Big Mike Link to comment Share on other sites More sharing options...
davecb Posted August 19, 2008 Share #6 Posted August 19, 2008 Will these work on Vance and Hines for Harleys?? Link to comment Share on other sites More sharing options...
davecb Posted August 19, 2008 Share #7 Posted August 19, 2008 OOPs....wrong thread Link to comment Share on other sites More sharing options...
Guest Lightnen Posted August 19, 2008 Share #8 Posted August 19, 2008 If you do get a set with cat's you can break them up and remove them. It is just an extra step and a little more work, but definitly worth it for that nice deep rumble. Big Mike Thanks there BigM. I'll try to finde the older ones then cause with my luck I'd prob knock out the baffels as well... Thanks to ALL who responded here for my request... Link to comment Share on other sites More sharing options...
boominup Posted August 19, 2008 Share #9 Posted August 19, 2008 If you do get a set with cat's you can break them up and remove them. It is just an extra step and a little more work, but definitly worth it for that nice deep rumble. Big Mike I drilled out a cat muffler with a 5/8" masonary bit. I poked a few holes next to each other and then broke the rest on the "brick" with a hammer and a long chisel. Took me about 15 mins. Then I poked the baffles out with a 1 1/8" hole saw. SWEEEET! Brian Link to comment Share on other sites More sharing options...
