rod Posted August 7, 2008 Posted August 7, 2008 I need to increase the volume of MP3s. I am a little deaf and while sitting the volume is enough but with wind noise I have to have the volume all the way up and that still is not enough. The radio volume is around 15 but Aux is all the way up and not enough. Any one know a good program that lets you adjust the level on the MP3 when you copy. Thanks Rod
Bummer Posted August 7, 2008 Posted August 7, 2008 I don't know what kind of player you're using, but if it has a built in equalizer you can turn that all the way up on all frequencies. That made a huge difference on mine.
Owen Posted August 7, 2008 Posted August 7, 2008 Some mp3 players (ipod and iphone specifically) have a setting to limit the audio output to 'safe' levels. On the ipod it is the 'sound check' setting. Off is non-limiting. Perhaps your device has a similar setting.
SilvrT Posted August 7, 2008 Posted August 7, 2008 check these out... http://www.goldwave.com/ http://audacity.sourceforge.net/
StarRider07 Posted August 7, 2008 Posted August 7, 2008 I need to increase the volume of MP3s. I am a little deaf and while sitting the volume is enough but with wind noise I have to have the volume all the way up and that still is not enough. The radio volume is around 15 but Aux is all the way up and not enough. Any one know a good program that lets you adjust the level on the MP3 when you copy. Thanks Rod Hi Rod. I use a program called Sound Forge made by Sony. http://www.sonycreativesoftware.com/soundforge Fantastic professional program that would be overkill for just increasing the volume. It does so much more. However, it does a fantastic job at increasing the volume. As you know, unless you get all your music from one CD, the volume is different between tracks. With this program, you can "Normalize" the volume so all your tracks are the same. No more turning up and down the volume. I also use this program to mix my music so that one song mixes right into the next for non stop music. And yes, you can still have the songs set as tracks so you can still skip songs. Hope this helps. PM if you want this.
V7Goose Posted August 7, 2008 Posted August 7, 2008 If you use an ipod, Belkin makes a 12v power cord that has a built-in amplifier, volume control, and audio out jack. This makes it very handy to match music output levels to the nominal radio volume levels. Goose
rod Posted August 7, 2008 Author Posted August 7, 2008 Wow thanks for all the replies. I will try them out. I have a MP3 player in the GPS that I use and it has very few features. I have been out of work for 2 yrs after the accident and just started teaching and wrenching part time for the MSF so money is real tight. The amps will be just the thing for the Virago (loud pipes) when I can scrape up the cash. The software should take care of the Venture. Thanks again Rod
SilvrT Posted August 7, 2008 Posted August 7, 2008 Wow thanks for all the replies. I will try them out. I have a MP3 player in the GPS that I use and it has very few features. I have been out of work for 2 yrs after the accident and just started teaching and wrenching part time for the MSF so money is real tight. The amps will be just the thing for the Virago (loud pipes) when I can scrape up the cash. The software should take care of the Venture. Thanks again Rod This is but one of the many great things here .... post a question and almost immediately get all the help one needs.
Gray Ghost Posted August 8, 2008 Posted August 8, 2008 Rod, I use MP3GAIN. Works great and it is free. The download for MP3GAIN is at: http://mp3gain.sourceforge.net/download.php
Stratcat Posted August 8, 2008 Posted August 8, 2008 I need to increase the volume of MP3s. I am a little deaf and while sitting the volume is enough but with wind noise I have to have the volume all the way up and that still is not enough. The radio volume is around 15 but Aux is all the way up and not enough. Any one know a good program that lets you adjust the level on the MP3 when you copy. Thanks Rod Try is editor Free (Shareware) professional level sound editor. http://www.reaper.fm/
Royal Venturer Posted August 8, 2008 Posted August 8, 2008 there is a little amplifier called a "boostaroo" you can get at radio shack or lots of plces on line. it plugs into your mp3 player and your headset plugs into it. they cost about 20 bucks. they work great, I had one.
