MikeM8560 Posted April 30, 2007 Share #1 Posted April 30, 2007 id like to have a headlight modulator but will one work with the headlamp safety feature? anyone have one? Link to comment Share on other sites More sharing options...
Gary N. Posted April 30, 2007 Share #2 Posted April 30, 2007 Don't know what the headlight safety feature is that you mentioned but this is the modulator I used. Model P115W http://www.kisantech.com/index.php?cat_id=2 Link to comment Share on other sites More sharing options...
Black Owl Posted April 30, 2007 Share #3 Posted April 30, 2007 I am also running the Kriss headlight modulator. Have been for seeralo years now, and man has the price gone up sine I put mine in. They currently have the signle lamp modulator in their close out section for $59.00....... That one will fork for you........ Link to comment Share on other sites More sharing options...
Tartan Terror Posted April 30, 2007 Share #4 Posted April 30, 2007 Mines a 2nd gen but I too use the HL modulator from Kisan. Works great and very visible. Link to comment Share on other sites More sharing options...
EasyRider Posted April 30, 2007 Share #5 Posted April 30, 2007 cage response so far. Add me to the list that uses that modulator. Link to comment Share on other sites More sharing options...
Bummer Posted April 30, 2007 Share #6 Posted April 30, 2007 I have a modulator on my high beam and another modulator, activated by the horn, on my passing lamps. Definately an attention getter. I've had cages pull over. Link to comment Share on other sites More sharing options...
MikeM8560 Posted May 1, 2007 Author Share #7 Posted May 1, 2007 the first gen has a feature if a low beam burn out the hight beam take over, i just though that this might be a problem thats for the response. is there a difference in the Kriss and Kisan? Link to comment Share on other sites More sharing options...
Gary N. Posted May 1, 2007 Share #8 Posted May 1, 2007 the first gen has a feature if a low beam burn out the hight beam take over, i just though that this might be a problem thats for the response. is there a difference in the Kriss and Kisan? The modulator comes with a photo light sensor that causes it to stop flashing after dark so your high beam will work normally even if the low beam goes out. Link to comment Share on other sites More sharing options...
Rocket Posted October 11, 2007 Share #9 Posted October 11, 2007 the first gen has a feature if a low beam burn out the hight beam take over, i just though that this might be a problem thats for the response. is there a difference in the Kriss and Kisan? I have recently tried the single bulb version of this setup, on my 83 VR http://www.webbikeworld.com/r3/headlight-modulator/dual-modulator.htm & found that the bike thinks high beam is burnt out. Link to comment Share on other sites More sharing options...
MikeM8560 Posted October 11, 2007 Author Share #10 Posted October 11, 2007 Thanks rocket, I still havnt tried one yet here Link to comment Share on other sites More sharing options...
Thom Posted October 11, 2007 Share #11 Posted October 11, 2007 i use the strobe sys. that randya uses , autozone 14.95 . 2 small strobes in the head lite bucket , draws very little power , i also use a small sw. with a blue lite in it , mounted on the key bizal , when it starts to get dark the windshield turns blue never forgot to turn it off . i have stopped using my driving lite and high beams during the day ,don't have to charge bat. as much anymore . the local leo's even like it ! Link to comment Share on other sites More sharing options...
wild hair 39 Posted October 11, 2007 Share #12 Posted October 11, 2007 i hooked mine to the driving lights,two 55 watter,have over 100000 mls on them ,have not replaced a blub yet Link to comment Share on other sites More sharing options...
DANJ Posted October 11, 2007 Share #13 Posted October 11, 2007 Thanks rocket, I still havnt tried one yet here Snag one Mike. You'll be amazed how much attention you'll get. If you hook it up as per instructions, you'll find that low beam works normally and the modulator works on high beam so it's easy to turn off. Mine is adjusted so it quits working just before dusk. The only drawback is it somehow convinces the computer that high beam is out and lights up the warning on the dash when it is working. At first I thought I would try to figger out how to disable the warning, but after a little thinking and seeing how the sensor works (warning goes out at dusk) I think I like knowing when it is working or not. My 2cents. DJ BTW, I got the Kriss on special and love it. Link to comment Share on other sites More sharing options...
CrazyHorse Posted October 11, 2007 Share #14 Posted October 11, 2007 I have the Signal Dynamics modulator. It causes the headlamp safety feature to display an error message on your computer. I found it annoying and disconnected it. I then mounted the modulator to my driving lights and acitivated them with a regular switch. I did not connect my driving lights to any low beam or high beam switch I dont care for that I wanted more control ( I know some states its not technically legal.). I had a switch just for them, used its own relay and ran them that way. They blink during the day like emergency flashers because my lights have a yellowish tint to them and at night they run just like regular driving lights. Now I dont know if the blinking will confuse some drivers if I put my turn signals on (which it may) but I figure they will freeze as if I would go straight. But if you still want to hook it up I saw a neat idea a guy came up with. Instead of cutting your headlamp wires you buy another lamp socket at the auto parts store. You then wire it by putting blades on your modulator wires into the regular lamp socket and run it from there. Thereby not damaging your origianl setup if you want to take it off. Link to comment Share on other sites More sharing options...
Gary N. Posted October 11, 2007 Share #15 Posted October 11, 2007 Have you had any problems with the police here? These are illegal in Ontario. Mike, These are definitely LEGAL in Ontario and I've got a print out of the law to prove it. I tried to find the link for you but I can't put my finger on it right now. To answer your question though, yes, I have been pulled over twice in the same small town, (local L.E.O.s)on the same day, ten minutes apart. I showed the copy of the law to the cops each time and they let me go. I've never had a problem with the O.P.P. or any others. Link to comment Share on other sites More sharing options...
Rocket Posted October 12, 2007 Share #16 Posted October 12, 2007 Mike, These are definitely LEGAL in Ontario and I've got a print out of the law to prove it. I tried to find the link for you but I can't put my finger on it right now. Here is a link, but can't find the "official" one though. http://www.webbikeworld.com/Motorcycle-Safety/Modulator-regs-canada.htm Link to comment Share on other sites More sharing options...
MikeM8560 Posted October 12, 2007 Author Share #17 Posted October 12, 2007 i use the strobe sys. that randya uses , autozone 14.95 . 2 small strobes in the head lite bucket , draws very little power , i also use a small sw. with a blue lite in it , mounted on the key bizal , when it starts to get dark the windshield turns blue never forgot to turn it off . i have stopped using my driving lite and high beams during the day ,don't have to charge bat. as much anymore . the local leo's even like it ! Thom i didnt see anything from Randya on this do you have any more info on theese storbes or a link? also you mentioned a small SW what is this and why would your window turn blue? sounds cool i think id like a blue window Link to comment Share on other sites More sharing options...
Gary N. Posted October 12, 2007 Share #18 Posted October 12, 2007 I found it. Here's the pdf file. Scroll to pg. 47. S7.9.4 http://www.tc.gc.ca/roadsafety/mvstm_tsd/tsd/1080rev4_e.pdf Link to comment Share on other sites More sharing options...
Thom Posted October 12, 2007 Share #19 Posted October 12, 2007 mike , i'll take some pic's and info this afternoon Link to comment Share on other sites More sharing options...
Thom Posted October 12, 2007 Share #20 Posted October 12, 2007 the strobe i used in the headlite is from autozone - pilot ip-400 14.95 and for the brakes pilot - wi-101w . 24.95 maybe you can see 1 of the strobes in the bottom left side , it is hard to see . the control box is stored behind the headlite . i just drilled 2 holes in the bottom of the headlite bucket and glued the strobes in with clear r t v . for the brake lites i removed 1 bulb form 2 of my running lites and put a strobe in it place , the strobe comes with sticky tape on the back , just peel and stick , the last 2 i stuck under the to tail lite bulbs in the tail lite . by the way these lites are all randya,s fault:rasberry: i do not take the blame i just copyed his :confused24:but for the money saved , i got my new bars and a lot more stuff:cool10: less than 50 bucks for front and brake strobes :cool10: Link to comment Share on other sites More sharing options...
Gearhead Posted October 12, 2007 Share #21 Posted October 12, 2007 That strobe setup is cool. If I'm not mistaken, the windshield turns blue because the blue light from the switch transmits into the windshield, and some of that light travels through the plastic (like in a waveguide) to the edges which then glow blue. I had a similar phenomenon in a shield I added to my Virago. It was picking up light from the headlamp on the lower edge and making the whole edge glow, only noticable at night. Very distracting. I installed a headlight visor which isloated the offending edge and it fixed the problem. Jeremy Link to comment Share on other sites More sharing options...
Thom Posted October 12, 2007 Share #22 Posted October 12, 2007 your rite , the good thing about it , i never forget to turn off the strobe at nite Link to comment Share on other sites More sharing options...
Gary N. Posted October 13, 2007 Share #23 Posted October 13, 2007 We had this discussion some time ago on here. What you're showing is the FEDERAL standard. Ontario had banned them (unless they've changed) as they are reserved for emergency service vehicle only. I'm trying to find the MTO documents but it's not obvious. I'll hunt some more. I did find this: Attachment that affects lamps prohibited (7) No person shall drive upon a highway a motor vehicle if either or both of the lamps that are required on the front of the vehicle by subsections (1), (2) and (3), (a) are coated or covered with a coloured material; or (b) have been modified by the attachment to the lamps or the motor vehicle of any device that reduces the effective area of the lenses or the intensity of the beam of the lamps. 2002, c. 18, Sched. P, s. 19 (1). Exception (7.1) Clause (7) (a) does not apply if the lamps are of the prescribed type or meet the prescribed standards. 2002, c. 18, Sched. P, s. 19 (1). I've asked the MTO for a response. We'll see what they say. This is probably like the MMP referendum.. no one knew what the hell is the truth. Is there a lawyer in the house? Maybe Reinyrooster knows, he's a prosecutor. Link to comment Share on other sites More sharing options...
Guest ReinyRooster Posted October 13, 2007 Share #24 Posted October 13, 2007 Well I can't say that I 've had to deal with this issue in court, hasn't come up yet but from what I've read on the subject, the headlight modulator is O.K. in Ontario. There are definitely rules against having any other colour lights flashing ( referring mainly to tail and brake lights) but nothing about the headlights. Link to comment Share on other sites More sharing options...
Black Owl Posted October 22, 2007 Share #25 Posted October 22, 2007 Spud, While they don't specifically use the word modulate, I do believe that Sect 63: 7(b) answers your question. Attachment that affects lamps prohibited (7) No person shall drive upon a highway a motor vehicle if either or both of the lamps that are required on the front of the vehicle by subsections ( (b) have been modified by the attachment to the lamps or the motor vehicle of any device that reduces the effective area of the lenses or the intensity of the beam of the lamps. 2002, c. 18, Sched. P, s. 19 (1). The modulator works by rapid cycling of a resistor which momentarily drops the intensity of the lamp. Link to comment Share on other sites More sharing options...
