jbabin Posted July 4, 2008 Posted July 4, 2008 I am getting ready to change the final oil on my 03 RSV, I just turned over 21,000 miles and this will be the second time I have changed it. I would like to change it over to synthetic and am looking for a recommendation. The service manual calls for SAE 80 API GL-4 hypoid gear oil, I found an SAE 75W-90 API GL-5 that is made/sold by Super Tech. Has anyone used this type of oil in their bike? Any feedback or suggestions would be helpful. Thanks
Guest cwil2988 Posted July 4, 2008 Posted July 4, 2008 I am not convinced on synthetics- used the conventional for years with little problems, but to each his own there. I use this myself http://www.lucasoil.com/products/display_products.sd?iid=43&catid=4&loc=show
Stoutman Posted July 4, 2008 Posted July 4, 2008 I run the GL-5 supertech oil. It works fine. I like to change it more often than most, every other oil change, 8000 miles. The used oil always comes out about the same color as going in, with very little darkening. I don't see much in the way of metal shavings on the magnetic plug. The manual says GL-5 rated oil is fine. I have heard others here state that they like the synthetic because it entrains less water and keeps the corrosion down. I've run the synthetic in the final drive and didn't notice any difference to speak of. The bike uses so little in the final drive that I change it more often. I've changed it at 4000 miles when I've had to take the saddle bag off to clean. I'll run any oil that meets the specs in the manual.
Jethroish Posted July 4, 2008 Posted July 4, 2008 My last final change, I used Castrol synthetic. I don't know about the gear oil, but I do know that the SuperTech motor oil is made and bottled by Quaker State.
Freebird Posted July 4, 2008 Posted July 4, 2008 I use Mobil 1 full synthetic. Don't remember the weight but I don't think they make but one. Seems like it was 75/90 or something but I'm not sure. I will continue to use it though.
Brake Pad Posted July 4, 2008 Posted July 4, 2008 Since the 07's have so many problems with the final drive, I use "Lucas" High Perfomance Heavy Duty Sae 80W-90 Gear Oil. Find , It holds up better then the Yamaha product My 07 has 21,798 miles on it
flb_78 Posted July 4, 2008 Posted July 4, 2008 I use the Mobil 1 75w90 as well. If you have ever worked on a big truck and seen the difference in conventional and synthetic gear oil, you too would run synthetic.
hig4s Posted July 4, 2008 Posted July 4, 2008 (edited) I use either Mobil 1 75w-90 gear oil or Castrol Syntech 75w-90 gear oil. I read a test on 14 gear oils,, Amsoil rated #1,, Mobil 1 #2, GM synth axle #3, Castrol Syntec #4 and Red line synth #5.. Royal Purple synth, Mopar synth, and Lucas synth all rated lower than Vavoline, Castrol or Penzoil conventinal gear oil. Castrol Hypoy conventional was the top rated conventional, 8th over all. Mobil 1 was the lowest priced of the top 5, Castrol second lowest priced, that is why I use them. I guess I should list all 14 all the synths are 75w-90 the conventionals are 80w-90 1 Amsoil 2 Mobil 1 3 GM synth axle 4 Castrol syntec 5 Redlin synth 6 Pennzoil synth 7 Valvoline synpower 8 Castrol hypoy (conventional) 9 Torco SGO synth 10 Valvoline High performance (conventional) 11 Pennzoil gearplus (conventional) 12 Royal purple max-gear 13 Mopar synth 14 Lucas synth Edited July 4, 2008 by hig4s
greg_in_london Posted July 5, 2008 Posted July 5, 2008 I'd go for a funky synthetic oil any time, but don't seem to have much choice around here on gearbox oils, so I've had to settle for semi-synthetic. My old oil has come out clean, though, and it's been so long I don't remember what it was, except it was good quality. Sorry, not very helpful I know.
Moped Posted July 6, 2008 Posted July 6, 2008 Trying to remember when I ever had a rear end problem gears or bearings using old dino oil?
