I have a 2002 RVS, with 135k and my rear brakes are soft and will not slide rear tire. I put new rotary on rear app 40k miles ago when I put on new tire, and they were a little soft but would slide wheel if I tried. About 16k miles ago I put on new rear tire and when I got it back together they, I bled the brakes, but they were a little softer than the last time, but I could still slide rear if I tried. I just put on another rear tire. This time I use a 1 man vacuum bleeder and still pump brake to bleed them the best I can. When  rode today I could not get the rear brakes to slide the tire. It has stopping power but very soft. Now the rotor that I put on was an after-market. I notice my old OEM rotor was app 7mm thick and was worn down to 4mm. The new after-market rotor was only 4mm thick brand new. Do you think this is my problem. Any help and advice will be appreciated. thank you
I’m not sure.   Certainly sounds like the new rotor is too thin but could also be other things.  You said you bled the brakes but how long since a complete fluid change?  At those miles, I would hope that has been done.  Other than that, which is the first thing I would try, it could be your master cylinder
  • Like 1
Have you flushed out the brake fluid to ensure there is no old contaminated fluid in the system?
Have you inspected or rebuilt the rear master cylinder?
Try getting a speed bleeder for the rear bleeder port, those work great make bleeding a breeze.
I would also consider going back to OEM rotor, you can check the specs on the rotor thickness requirements in the service manual found in the tech section here on the forum.
Well I see Freebird beat me to it as I was typing.
  • Like 1
I have not done a complete fluid change. Never have done one, but maybe that is the time. With my vacuum pump, I never could get a complete stream of fluid. Never had fluid go bad. Thank you.
Brake fluid is hydroscopic, meaning it has a affinity to absorb moisture, water although considered to be an incompressible fluid, often has dissolved air in it, that dissolved air is compressible.  Just as a note, Honda recommends the entire brake hydraulic brake systems on the Goldwings be flushed and replaced with new fluid, every two years, that system is a bit more complex that that on a Venture, but replacing your brake fluid at some regular interval be it time or miles, is a good thing to do. Again Speedbleeders make that job way easier to do, just pump the old fluid out into one of their catch bags using the lever or pedal depending on front or rear brakes, refill the master cylinder before it is empty and your done in no time.
  • Like 1
OK. I drained and ran new DOT synthetic fluid today. Still can not get full pedal. Rode the bike and it will not slide tire on dirt road. Looks like there is still air coming out while using the vacuum pump. Why is that? Is there a trick to bleeding to get air out. As I said every time I change a tire off, my brake pedal got softer. Does the rear brake pedal operate just the rear or is it like a goldwing, front and back?
49 minutes ago, Freebird said:
The brakes on the RSV are not linked.    Take a look at this thread.
Did he rebuild it??? Did it correct the problem??? thank you
On 8/16/2025 at 7:43 AM, Freebird said:
 I, he did not in this case.   Just the rubber diaphragm and slipped down.
I have fluid coming using my vacuum bleeder, but it still looks like air bubbles coming into line from the bleeder valve. I took bleeder valve out and put thread tape on, replaced and still looks that way. I have never done brakes other than pump and bleed on cars. Is there sometime I am over looking or a trick to bleed. I read somewhere about someone using what they called reverse bleeding, where you force fluid back into the reservoir thur the bleeder valve. I'm at my wits end. Any suggestions will be appreciated. If you know of anyone on here that could help. Thank you in advance.
It is possible that you need to rebuild the master cylinder. It's not a difficult or expensive job, but sometimes necessary.
I know...Dumb question, but I gotta ask....
When bleeding by pumping the pedal, are you tightening down the bleeder screw before releasing the pedal?
If bleeding with a vac pumper, are you tightening down the bleeder screw before removing?
I'm just wondering if you're letting air back in after bleeding....
Yes, open and close like always when doing a car. I did not know if there was a problem with an air bubble like I had on my gold wing clutch. It seems like it should be easy, but my brake got worse every time I changed my rear tire.
  Don't know if it applies the same in this situation, but I know a collapsed brake line can cause some problems.
  When you bleed at the caliper, does it seem to have good pressure?
  • Like 1
It has been a long time since I had my Venture, so I have forgotten a lot about it, but if the Venture has any rubber lines in the rear brake system, it may be that those sections have weakened over time and stretch or expand when pressure is applied.  If there are rubber sections, maybe it is time to replace them, preferably with braided steel covering. Just a thought.
This would not necessarily have anything to do with air bubbles, but could affect the ability to lock up the rear wheel and slide it, which the Venture should do very easily, as the rear brakes are known to do that even of good dry pavement.
  • Like 1
  • 2 weeks later...
12 hours ago, BlueSky said:
You said you used synthetic fluid.  What DOT number is it?  DOT 5 is not compatible with our brakes.  DOT 3, 4, and 5.1 are compatible.
I use dot 4
  • Like 1
OK, I rebuilt the master cylinder and reinstalled. Can not get to pump back up. I tried to use a vacuum bleeder and got some fluid to go down some in the reservoir, but can not get any more to go down, all while holding vacuum on the bleeder. Tried pumping the pedal  slowly with vacuum, still not fluid going down. I tried a 1 man bleeder that I just purchased and can not get fluid at bleeder valve at rear brake. I'm at my wits end. Any advice and help will be appreciated. . Tomorrow I will try reverse bleeding by using a big syringe that I bought a Orileys. Hope thar helps. Thank you in advance
So....I wonder if you were to remove the hose from the master cylinder and immerse it in a container of brake fluid and try the vacuum bleeder at the wheel cylinder....would it draw through the hose?
If not, then that would seem to indicate an issue within the brake tubing between the master / slave cylinder.
Edited by uncledj
I hooked my vacuum to the bleeder and took line loose at master cylinder, and it pulled a vacuum on my finger. It is open. I took MC off and went back in to make sure seals were correct, had a friend look also, they were correct. We fill the MC with fluid the best we could and filled the reservoir down to MC the best we could and connected lines. Still can not get a pedal. Tried reverse fill with a large tube like a syringe all while working the brake pedal. Tried reverse fill again. Still cannot get a pedal. I have now tied the brake pedal all the way down and will leave overnight. (old trick). I also beat and vibrated the brake lines from MC back to caliber especially where the line has high spots. If This does not help, I plan to take it to someone that is supposed to know. Has anybody else had this problem bleeding the venture?????
Hmmm..
I do know from experience that when replacing, or in your case rebuilding a master cylinder it can be a pain to get the juice to flow at first.
With the master full and the brake line disconnected at the master, what happens when you pump the brake handle?
I don't think the front / rear brakes are linked on the second gen...not sure though.   If they were I'd wonder about the proportioning valve.
Someone should chime in and confirm or deny that they're linked.
It doesn't seem that it should be this difficult, but I've had similar situations.  (Don't make sense)   I feel your pain, but I think if you stick with it you'll find the answer.   It sounds like (so far) you've been checking all the boxes.
Brakes are not linked on Royal Star Ventures.
May be a collapsed line somewhere. Start at the outlet of the master cylinder break that connection and press on the pedal, if fluid freely flows, reconnect and work your way down the line until you find a point where the flow is diminished, if you get to the bleeder valve on the caliper and do not find an issue, maybe the calipers are stuck or dirty to the point they will not move freely.
  • Like 3
