Junior Posted November 19, 2024 Posted November 19, 2024 Have a leak at the seal area on the shift shift. Anyone ever change this out
Marcarl Posted November 19, 2024 Posted November 19, 2024 Year and model is helpful, and yes, they can be changed out. Takes a bit to get to it but does work.
saddlebum Posted November 20, 2024 Posted November 20, 2024 (edited) On 11/19/2024 at 8:18 AM, Marcarl said: Year and model is helpful, and yes, they can be changed out. Takes a bit to get to it but does work. Just do not recommend using the sheet metal screw method to remove the seal. The tolerances are tight and you risk scoring the shaft. Don't ask how I know. Lets just say I am now looking for a speedi sleeve to fit the shaft. Edited November 20, 2024 by saddlebum
Junior Posted November 20, 2024 Author Posted November 20, 2024 Thanks for the reply. I have a 2007 RSV that I just changed the slave cylinder and while I was doing that I noticed oil leaking from the shaft seal. I've read other people's comments about this job and they mentioned to check this out before closing cover up. Well I ordered a seal and I was hoping someone had replaced this easier than what the manual said. Thanks again for your comments.
Junior Posted November 21, 2024 Author Posted November 21, 2024 Thanks for more comments on this subject.
saddlebum Posted November 21, 2024 Posted November 21, 2024 Another solution is to park by the Harleys, then no one will notice. 2
Junior Posted November 22, 2024 Author Posted November 22, 2024 It is ! Thanks, I enjoyed your comment
