Venturesuperfan Posted March 30, 2023 Share #1 Posted March 30, 2023 Hello all,was just wondering if anyone did a step by step visual(pictures) service job on their first gen Venture for the starter clutch? Was searching this section and couldn't find any...Any help in this would be greatly appreciated!!! Thank you!!! Link to comment Share on other sites More sharing options...
RDawson Posted March 30, 2023 Share #2 Posted March 30, 2023 It’s in the manual that’s downloadable here. A tip for you: use a good puller on the flywheel, get it set and use a strap to tie it to the bike. When the flywheel comes loose it’ll usually launch itself. I tighten the puller down and give it a couple sharp raps with a hammer, tighten again-rap again ……. It’ll pop all at once. Some people get the puller tight and walk away until the launch. Link to comment Share on other sites More sharing options...
Venturesuperfan Posted March 30, 2023 Author Share #3 Posted March 30, 2023 Thanks for the info,RDawson!!! Yeah,I keep reading about the ''pop'' launch!!! Hahahaha!!!...I've worked on other vehicles and have had them do this,so I guess I'll wait for the POP!!! on this one too!!! Hahaha!! Link to comment Share on other sites More sharing options...
Marcarl Posted March 30, 2023 Share #4 Posted March 30, 2023 Lots of tension, a good strap and a box of rags to catch the results. Now a good solid punch and a heavy hammer and rap the clutch with the punch and hammer right close to the shaft. Might help. Link to comment Share on other sites More sharing options...
saddlebum Posted April 2, 2023 Share #5 Posted April 2, 2023 On 3/30/2023 at 8:14 AM, Marcarl said: Lots of tension, a good strap and a box of rags to catch the results. Now a good solid punch and a heavy hammer and rap the clutch with the punch and hammer right close to the shaft. Might help. I recommend a heavy brass punch. Link to comment Share on other sites More sharing options...
