Pop Posted July 12, 2022 Posted July 12, 2022 I am coming from the first gen list looking for a fuel pump. Got lots of great suggestions there. There does not seem to be a source for new fuel pumps for an '87 Venture Royale. Anyone here know if a Royal Star fuel pump can be rigged to use in my first gen? Thanks!
RDawson Posted July 12, 2022 Posted July 12, 2022 Oreilly sells a low pressure pump I used in my 86. Mr. Gasket I believe. Had to add a fitting or two to get the angle on the line.
Pop Posted July 12, 2022 Author Posted July 12, 2022 Thanks for the reply RDawson. Is this it? https://www.oreillyauto.com/detail/c/mr-gasket/mr-gasket-95-gph-fuel-pump/mrg0/95p?q=Mr+Gasket+low+pressure+fuel+pump&pos=5
RDawson Posted July 12, 2022 Posted July 12, 2022 It’s a very small low pressure pump. I don’t remember the pressure but it’s low.
Marcarl Posted July 14, 2022 Posted July 14, 2022 On 7/12/2022 at 4:09 PM, RDawson said: It’s a very small low pressure pump. I don’t remember the pressure but it’s low. 4-5 lbs if I remember correctly.
BlueSky Posted July 14, 2022 Posted July 14, 2022 95 gph sounds like a lot since a bike uses about 2 gallons per hour. But what do I know?
