kenblount Posted August 24, 2020 #1 Posted August 24, 2020 Taking granddaughter on a ride and motorcycle acted as if i was running out of gas , was close to gas station put only a gallon in. What do it need to check?
RDawson Posted August 24, 2020 #2 Posted August 24, 2020 Is the pump clicking when you turn the key? Fuel filter clear?
SpencerPJ Posted August 24, 2020 #3 Posted August 24, 2020 Sounds like the filter to me. O'Reilly sells a nice one that is clear glass. I also had a bad gas line, got pinched and starved the process. I replaced with a flexible one, made my problem worse, it would collapse under hard acceleration. I finally found the right combo and 'knock on wood', been good for a few years.
BlueSky Posted August 24, 2020 #4 Posted August 24, 2020 Would you tell us a little more about exactly what it's doing? Does it idle ok? Does it cut out when throttle is applied? I would put a bottle of seafoam or gumout with PEA in the gas to begin with. If it's cutting out when revving, a carb diaphragm might be ruptured? Fuel pump points failing seems to be a Gen 2 issue. Just wagging here. Fuel tank vent?
Patch Posted August 26, 2020 #5 Posted August 26, 2020 The model matters as does the year and mods. Try checking the air vents.
kenblount Posted August 27, 2020 Author #6 Posted August 27, 2020 XV1100SE said: Just noticed you put this in the 1st Gen section. What year is your bike? 1983 yamaha venture royale update I put in a new petcock now have a small leak at the petcock where the unit meets the tank.
