AlbertaClipper Posted May 18, 2008 Share #1 Posted May 18, 2008 Have any of you that have a Zumo 550 noticed a drop in volume when listening to mp3 or XM thru the Zumo? When I am listening to FM or to my mp3 player I usually have my volume set at 17-18 but if I switch to the Zumo and listen to mp3s or XM I have to turn the volume up to 27-28 to get the same sound level. Is this normal:confused07: Link to comment Share on other sites More sharing options...
BuddyRich Posted May 18, 2008 Share #2 Posted May 18, 2008 Theres a volume control on it. Hold the button with the square till you get a pop up for the brightness. then push it again ( or the button next to it I forget) and it will switch sides of the screen and will be the volume for the output Link to comment Share on other sites More sharing options...
Cougar Posted May 18, 2008 Share #3 Posted May 18, 2008 Set the volume lower on the MP3 Side and Up to 100% on the Sound for the Directions... then crank up your RSV Volume, I am guessing having an AMP in my trunk helps the Zumo a bit for me though. (or in your case after re-reading do the opposite) Jeff Link to comment Share on other sites More sharing options...
Jercoupe Posted May 18, 2008 Share #4 Posted May 18, 2008 I was very disapointed with the zumo when i first cranked it up but found shortly it has a volume of its own. I have it set for 100% and i only use the rsv volume now to adjust everything. works good. Link to comment Share on other sites More sharing options...
AlbertaClipper Posted May 19, 2008 Author Share #5 Posted May 19, 2008 I was very disapointed with the zumo when i first cranked it up but found shortly it has a volume of its own. I have it set for 100% and i only use the rsv volume now to adjust everything. works good. Yeah, that's how I do it too. I have all the Zumo levels set to 100% and I control the volume with the bikes audio control. When I use my mp3 player (not mp3s on the Zumo) I set its volume at 100% also. I think the audio out of the Zumo is not as strong as my mp3 player or the bikes FM radio. I posted this on the other Venture forum and someone suggested an additional inline booster. Maybe I'll try that. Thanks all for your input. Link to comment Share on other sites More sharing options...
