okiefirefighter Posted May 16, 2008 Posted May 16, 2008 I have read that everyone says to put on a set of Progressive springs on the front. I am going to have my forks rebuilt and I wanted to know if this is the time to install them? They go inside of the fork tubes right? Does anyone know where I can get a set and what the part number is? Can I still use the air suspension? Thanks, Kevin
Ozark Posted May 16, 2008 Posted May 16, 2008 I believe I ordered mine direct from Progressive, but there are several aftermarkets. I'm not running any air in the front forks after I installed the new springs, and yes, this would be the ideal time to install them. P.S. I love the new ride and handling.
funrider Posted May 16, 2008 Posted May 16, 2008 got mine form the old bike barn. http://www.oldbikebarn.com/ Just put them in a few weeks ago and love the way it rides and handles now. Can put it on the side stand without it setting so straight up and down that I thought it was going to fall over.
Rocket Posted May 16, 2008 Posted May 16, 2008 Does anyone know where I can get a set and what the part number is? Can I still use the air suspension? Thanks, Kevin The progessive part is #11-1112, yes you can still run air if needed / wanted.
Dano Posted May 16, 2008 Posted May 16, 2008 Just got mine in from MAW (Motorcycle Accesory Warehouse) about 75 bucks with shipping. Dan
rhncue Posted May 17, 2008 Posted May 17, 2008 I just put new Progressives in both the front forks and on the rear shock. i already had Progressives in the front and thought they had went bad but actually it was the rear spring giving such a rough ride. Made all the difference in the world. I got them from Rick Hafferkamp at: http://www.buckeyeperformance.com/ Dick :)
