okiefirefighter Posted April 30, 2008 Share #1 Posted April 30, 2008 Ok, I took the airhoses loose and now I can't figure how to get the air hose connections off to slide the forks out. I need help!!!!!! Thanks, Kevin Link to comment Share on other sites More sharing options...
Squeeze Posted April 30, 2008 Share #2 Posted April 30, 2008 Are you talking about the Connector Rings on the Forklegs ? If so, just turn them a bit clockwise and counterclockwise until they move. Might be a good Idea to use some Liquid to help them moving after they are loose. WD40, Silicone Spray or something in that Line. Once they turn easy, you can pull them up carefully. Now, remove the Circlips underneath the Air Connectors and you can pull the Legs out. Link to comment Share on other sites More sharing options...
BradT Posted May 1, 2008 Share #3 Posted May 1, 2008 If so, just turn them a bit clockwise and counterclockwise until they move. They may be very tight. I had a hard time moving mine, but after a lot of pushing turning they finally moved. BRad Link to comment Share on other sites More sharing options...
Squeeze Posted May 1, 2008 Share #4 Posted May 1, 2008 They may be very tight. I had a hard time moving mine, but after a lot of pushing turning they finally moved. BRad I didn't take any Chances and sprayed the Forktubes for Cleaning and Lubricating before even trying to move them. Link to comment Share on other sites More sharing options...
okiefirefighter Posted May 12, 2008 Author Share #5 Posted May 12, 2008 It is where the air hoses connect at the top. Kevin Link to comment Share on other sites More sharing options...
Dano Posted May 12, 2008 Share #6 Posted May 12, 2008 You won't need to disconnect the air hoses if you get them to slide. Dan Link to comment Share on other sites More sharing options...
