Glenabby Posted May 31, 2018 Share #1 Posted May 31, 2018 For those of you who have installed the heal and toe shifter do you still have the washer and retaining clip on the backside of the pivot? Mine has disappeared twice now. I think if you touch the shifter on an angle it pops the retaining clip off. I might have to drill a hole in pivot and use a cotter key. Link to comment Share on other sites More sharing options...
Patch Posted June 6, 2018 Share #2 Posted June 6, 2018 "retaining clip " Not sure what type of clip is in use? But if it is the spring type then you could wire the 2 eyes together neatly. Seems to me that the ID is incorrect? Link to comment Share on other sites More sharing options...
Glenabby Posted June 7, 2018 Author Share #3 Posted June 7, 2018 Thanks Steven G. That is a good idea. The eyelets are very small though so will have to find some fine wire. Link to comment Share on other sites More sharing options...
Patch Posted June 7, 2018 Share #4 Posted June 7, 2018 Picture hanging wire, twist is toward the engine! OR Last night I remembered that on my other bike which has a custom heal toe, I used a Teflon or nylon washer! Keep it thin in cross section. There is also easy to find brass washers with a higher copper mix. Look in the home or lowes keeping it thin.. Could also board sand one to fit Likely 13 or 14 mm id should do it Cheers Link to comment Share on other sites More sharing options...
Rasa Posted November 5, 2018 Share #5 Posted November 5, 2018 I was wondering does the heel part of the shifter sit above the floorboard or behind it? Could you post a picture of it on your bike? Thanks Rasa Link to comment Share on other sites More sharing options...
Kretz Posted November 5, 2018 Share #6 Posted November 5, 2018 (edited) I was wondering does the heel part of the shifter sit above the floorboard or behind it? Could you post a picture of it on your bike? Thanks Rasa On my RSTD Definitely both, sits above (about 1-2") & back from the FB about 2" sorry the pic is poor but it's dark in the garage. Edited November 5, 2018 by Kretz Link to comment Share on other sites More sharing options...
darylbandy Posted November 11, 2018 Share #7 Posted November 11, 2018 I just got this installed last night. This part should have come stock on such and expensive bike in my opinion. Link to comment Share on other sites More sharing options...
sldunker Posted January 9, 2019 Share #8 Posted January 9, 2019 For those of you who have installed the heal and toe shifter do you still have the washer and retaining clip on the backside of the pivot? Mine has disappeared twice now. I think if you touch the shifter on an angle it pops the retaining clip off. I might have to drill a hole in pivot and use a cotter key. Did you ever figure this out. I installed heel toe shifter on mine and was very careful with install and I see today it is gone. May try aftermarket snapring as I think oem is to soft and it deforms. Link to comment Share on other sites More sharing options...
