Patmac6075 Posted June 2, 2017 #1 Posted June 2, 2017 I'm having a problem with fork oil leaking out of one fork tube right where the anti-dive attaches...I have replaced the O-rings twice and I'm still getting a leak...funny thing was, I made it almost two season without a leak...now I've made the switch twice with new Yamaha O-rings and I'm still leaking. Anyway, does anyone know the torque spec? Since it's aluminum I want to make sure I don't over tighten. Thanks Pat
Flyinfool Posted June 2, 2017 #2 Posted June 2, 2017 (edited) Not sure if your MK1 is the same spec as a MK2. The service manual for a MK2 calls for 7Nm or 5.1 Lb/Ft. You can download a MK1 service manual here. http://labs.trunkful.com/vrmanuals/8385servicemanual.pdf Edited June 2, 2017 by Flyinfool
Flyinfool Posted June 2, 2017 #3 Posted June 2, 2017 I found it. Page 284 of the PDF from above, or page 5-29 of the manual. 8Nm or 5.8 Lb/Ft. for the two mounting screws for the anti dive to the fork leg.
Marcarl Posted June 3, 2017 #4 Posted June 3, 2017 Are you sure it's fork oil and not brake fluid? 5.8lb is no torque at all, I would call that snug, but not tight. If it's fork oil you either have a bad o-ring, dirt in the seal area or a cracked anti-dive I think.
Patmac6075 Posted June 4, 2017 Author #5 Posted June 4, 2017 Thanks Jeff and Carl... I'm absolutely positive it's fork oil, that side has been clean twice and this is the second set of O-rings. During my rebuild and the second time fix, I knew it was being tightened into aluminum so I just snugged up the anti-dive. This is really becoming a PIA! Does anyone have a template for a block off plate (where I work, we have a complete machine shop), I know Skydoc sells them, but he doesn't have any right now. If not , I might just start collecting parts for a MKII set of fork tubes/wheel/rotors/and either blue dots of MKII calipers.
camos Posted June 4, 2017 #6 Posted June 4, 2017 Patmac6075 said: I'm absolutely positive it's fork oil, that side has been clean twice and this is the second set of O-rings. During my rebuild and the second time fix, I knew it was being tightened into aluminum so I just snugged up the anti-dive.Have you sprayed the anti-dive area with something like baby powder or talc to find out precisely where the leak is occurring? I'm with Carl, good o-rings,, clean and torqued should be all that is necessary to prevent leaks. So cracked or warped or a burr could be the other reasons for a leak there. Patmac6075 said: Does anyone have a template for a block off plate (where I work, we have a complete machine shop), I know Skydoc sells them, but he doesn't have any right now. Any machinist should be able to make a block off plate using the anti-dive for the measurements. A template could be made by coating the face of the anti-dive with something like oil or grease then stamping a clean piece of paper. Patmac6075 said: If not , I might just start collecting parts for a MKII set of fork tubes/wheel/rotors/and either blue dots of MKII calipers.Whether or not you fix the leak, upgrading to MkII forks would be a good plan considering the anemic reputation of the MkI brakes.
ricksbike Posted June 4, 2017 #7 Posted June 4, 2017 Patmac6075 said: I'm having a problem with fork oil leaking out of one fork tube right where the anti-dive attaches...I have replaced the O-rings twice and I'm still getting a leak...funny thing was, I made it almost two season without a leak...now I've made the switch twice with new Yamaha O-rings and I'm still leaking. Anyway, does anyone know the torque spec? Since it's aluminum I want to make sure I don't over tighten. Thanks Pat A friend of mine had the same problem on his 83VR,he found a used part at the salvage yard,replaced it and problem was solved,by the way we changed the O-rings 3 times,to no avail. Good Luck
Flyinfool Posted June 5, 2017 #8 Posted June 5, 2017 Inspect the mating surfaces with a magnifying glass especially the o-ring surfaces, both halves. It does not take much of a nick or burr or piece of dirt to cause a leak.
