rebelbull69sbcglobal.net Posted April 21, 2008 Posted April 21, 2008 i have a 1984 venture for a couple of years when i aired up the front forks they leaked out after a couple of days but finally they went out. Now when i air them up they stay for about 10 minutes then there is no more air left. i cant hear any leaks. Is this the fork seals or what? new to working on the bikes and need a little help thanks alot
bongobobny Posted April 21, 2008 Posted April 21, 2008 You could try the old soap bubble thing to try to isolate the leak. May be a bad "o" ring on the line where it comes into the tube, or maybe a bad soleniod on the comperssor unit under the trunk mount under the plastic cover...
Squidley Posted April 21, 2008 Posted April 21, 2008 Chris, Is your bike a standard or does it have the CLASS system on it. If your not seeing it leak with the soapy water trick on the fork tubes then I would start looking at the tops of the forks behind the fairing. Like Bob mentioned there are 4 orings at the top of the forks, I would check there too. If it has the class system....then you have some other fittings to check
rebelbull69sbcglobal.net Posted April 21, 2008 Author Posted April 21, 2008 i believe it is just a standard i dont think it has a compressor on it ill try that out thanks guys
BradT Posted April 22, 2008 Posted April 22, 2008 If you use progressive springs you do not need the air. When I fixed my leking fork seals I put in progressive springs and then had an air leak after, but did not even worry where it came from. BRad
rebelbull69sbcglobal.net Posted April 29, 2008 Author Posted April 29, 2008 i checked the valve stem where you air them up the hoses all the way to the forks and where they screw in all was good except i had a air leak on the right fork the rubber seal/gasket the one that connects the upper and lower part of the forks is there a way to fix this? i pushed them down and it worked but they have a little leak no matter how you press it it just moves around the seal. also is this seal a fork seal or is it insidE? thanks very much for all yalls help
Squidley Posted April 29, 2008 Posted April 29, 2008 Chris, It sounds to me like you have a fork seal leaking, it is under the black rubber dust seal cover. It is on the inside and takes some skill to take it apart and repair it. If your not real familiar with how to do it I would say take it to someone that does it for a living. It can be a pain to do if you dont have the right tools. Some folks have removed the fork from the bike and brought the forks into a dealer and had them do it for the cost of an hours labor. Something I will mention here is when you do replace them, use Yamaha parts. Dont go with the "Never leak again" seals the factory parts for this application are the best your going to get and you dont want to screw with them again.
