cwhite123174 Posted March 29, 2017 #1 Posted March 29, 2017 Any of you guys have problems with them? Works fine. Just doesn't seem to hold the car charger very well. Constantly rattles itself out and I have to reach down and click it back in. Good ole Eusa1.... Mike, has a spare I will be getting from him.
Bert2006 Posted March 29, 2017 #2 Posted March 29, 2017 Fuse blew out first time I used it. I have since started to plug things directly to battery through dedicated circuits.
cwhite123174 Posted March 29, 2017 Author #3 Posted March 29, 2017 Bert2006 said: Fuse blew out first time I used it. I have since started to plug things directly to battery through dedicated circuits. Really? I used mine all last year and didn't have problems except it kept wanting to pop out... Lol!
Jcgfree Posted March 29, 2017 #4 Posted March 29, 2017 I have the same problem as I plug my GPS in it. Rattles itself out enough to lose connection ever so often. I took a piece of this cardboard from a parts box and wedge it in there like a shim on the side of the plug when I plug in.
cwhite123174 Posted March 29, 2017 Author #5 Posted March 29, 2017 Yeah. I do the same thing but I was curious how many other RSV owners have had the same issue. This method works but I want to make it right, if ya know what I mean.
djh3 Posted March 30, 2017 #6 Posted March 30, 2017 I found it more to be the 'type" of plug. My Garmin would back out, so I wired it up with its own plug eventually. Problem solved. Then I started for a little bit a del plug before I made the dedicated power. One side for GPS one side for phone. You know that cheap ole piece of junk would stay in no problems. Then I tried my phone charger in the plug and it was hit and miss. I put the duel plug splitter in and it fine So I just went with that for a long time until the duel plug died. So Maybe the plug itself (GPS/phone). I know if it is a longer plug with the like 45 on it they se to walk out more on me. Good luck.
videoarizona Posted March 30, 2017 #7 Posted March 30, 2017 Maybe something like this will help... https://www.amazon.com/Marine-Grade-Cigarette-Lighter-Socket/dp/B0002KRC5Y Regardless, I tapped into the socket wiring inside the fairing and ran a 2 plug wire out and it's on the handlebar. So I have a secure connection if I need it.
djh3 Posted March 30, 2017 #8 Posted March 30, 2017 I finally just cut to the chase and installed one of these and then used a USB cord to fit phone and the same for the GPS. the heat shrink connection @ USB to seal. Made it less messy also as I could tie wrap the wires with the clutch and brake hoses.
M61A1MECH Posted March 30, 2017 #9 Posted March 30, 2017 If anyone wants to tap into the two pin connector inside the fairing, shoot me an email or PM I have a plug and play set up for that.
videoarizona Posted March 30, 2017 #10 Posted March 30, 2017 M61A1MECH said: If anyone wants to tap into the two pin connector inside the fairing, shoot me an email or PM I have a plug and play set up for that. That's what I did with your parts. Now...do you have a 1 into 3? Thinking of adding some LED's to my front fairing and need another couple of taps!! Grins!
M61A1MECH Posted March 30, 2017 #11 Posted March 30, 2017 videoarizona said: That's what I did with your parts. Now...do you have a 1 into 3? Thinking of adding some LED's to my front fairing and need another couple of taps!! Grins! I can make what ever you like, if you want to tap into the running lights or turn signals I have special custom made 1 to 2 and 1 to 3 bullets that will let you tap into those easy as pie. Send me a PM or E-mail and we can figure out what will suit you the best.
