sfcrader Posted June 4, 2016 Posted June 4, 2016 I went ahead and purchased a set of passing lamps from eBay to go along with me new headlamp. http://www.ebay.com/itm/2-30W-4-5-inch-Cree-LED-Harley-Motorcycle-Daymaker-Auxiliary-Fog-Driving-lights-/361250657595?fits=Make%3AHarley-Davidson&hash=item541c37953b:g:lnIAAOSw3mpXL-W5&vxp=mtr I found out that the back of the light needs to be modified or find a smaller hollow bolt. I went with he modification, the center rid needs to be trimmed back in order to use the stock hollow bolt: Old and new passing light installed: Lights on side by side look: Old passing light look: New passing light look: All new just need to adjust the lights tonight:
flynvy5 Posted June 13, 2016 Posted June 13, 2016 I did mine about a month ago but I cut the stock bolt down by half and it worked great.
Wizard765 Posted June 14, 2016 Posted June 14, 2016 Looks amazing and if the light is better than stock Wow!! Are you experiencing any interference with your radio?
sfcrader Posted June 14, 2016 Author Posted June 14, 2016 Thanks, yes they are a lot better than stock and take less amps to use. So far no interference at all.
Rafterd Posted June 25, 2016 Posted June 25, 2016 Installed my headlight got ready to install driving lights and guess what, they fell through the rims. My driving lights are 4 3/4 inch new ones are 4 1/2. Any ideas? Bill
sfcrader Posted June 26, 2016 Author Posted June 26, 2016 Not sure, do you have OEM passing lamp? also with passing lamps did you get?
Sylvester Posted May 25, 2017 Posted May 25, 2017 Looks awesome..What headlight is that? Yes for me, what headlight is that.
Kretz Posted May 25, 2017 Posted May 25, 2017 Looks identical to the ones I got, Main & Passing, all I got to do now is get off my a$$ & get them fitted! LOL
sfcrader Posted June 16, 2017 Author Posted June 16, 2017 Yes for me, what headlight is that. I purchased the headlamp on ebay it was around $100 not sure what brand. I will go back and look, I do remember it did saying Daymarker.
sfcrader Posted June 16, 2017 Author Posted June 16, 2017 How did you mount headlamp I tried something that did not work. Than I found this website:http://venture.eurekaboy.com/headlightmod.htm I purchased a used headlamp off ebay and used that one to cut. I took my time did not want to rush and spent a complete weekend. The hardest part is trimming both the buckets and the back of the headlamps and passing lamps.
sfcrader Posted June 17, 2017 Author Posted June 17, 2017 This is another thread I started that showed what I had to do to make the LED Headlamp work. http://www.venturerider.org/forum/showthread.php?119811-Changing-to-a-LED-Headlamp hope it helps.
