hoochster Posted January 7, 2016 Share #1 Posted January 7, 2016 I am pretty sure that is not the technical name for the covers but I was wondering if I put the covers back on correctly? Unfortunately, I didn't think about taking a pic prior to removing all 4 covers when I was doing some maintenance on the carburetors. I am not sure if the fuel drain screws are supposed to be all facing the same direction or if they are all supposed to be facing inward. Would someone please take a look at the picture and let me know? Thanks in advance for your help. Brian Link to comment Share on other sites More sharing options...
k9cottage Posted January 7, 2016 Share #2 Posted January 7, 2016 all facing out is the way to go the bottom 2 in the pick are wrong [float bowls] Link to comment Share on other sites More sharing options...
MiCarl Posted January 7, 2016 Share #3 Posted January 7, 2016 all facing out is the way to go the bottom 2 in the pick are wrong [float bowls] Yes, bottom two bowls need to be switched with each other so the drain screws point out. I see the brass caps either haven't been removed or were reinstalled after service. If you were cleaning the carburetors and didn't remove those go back. You need to remove the pilot screws under them to properly clean. Then leave the caps off. The EPA makes Yamaha put those on to prevent you from adjusting the mixture. You're going to want to adjust the mixture, regardless of what the EPA thinks. Link to comment Share on other sites More sharing options...
hoochster Posted January 8, 2016 Author Share #4 Posted January 8, 2016 Ok, Thanks for the info. I did remove the brass caps to adjust the mixing screw becasue I replaced the jets with the Ivan's Performance ones. I didn't remove the mixing screw to clean them just adjusted them. I didn't think they needed to be cleaned but maybe I should clean them since I have the carbs out already. Thanks again for the responses! Link to comment Share on other sites More sharing options...
OleBrown Posted March 25, 2023 Share #5 Posted March 25, 2023 Here is a before/after of my pilot screw cleaning effort Link to comment Share on other sites More sharing options...
Marcarl Posted March 26, 2023 Share #6 Posted March 26, 2023 Sooo much better. Link to comment Share on other sites More sharing options...
