DragonRider Posted August 28, 2015 Posted August 28, 2015 Has anyone found another source other than Yamaha for the gaskets that go between the muffler and the collector. I find they want anywhere between 18.00 up to 26.00 apiece for them. That is an outrageous price for a gasket.
Condor Posted August 29, 2015 Posted August 29, 2015 Years ago someone on this board used copper wire to wrap the collector ends with some success. In the later years yamaha switched to what looked like a carbon/filament sleeve. The earlier sleeves were made out of copper.
GeorgeS Posted August 29, 2015 Posted August 29, 2015 There are a few items on the 1st gens, that are best replaced with OEM parts. The muffler gaskets are one of those items. I fought with them, tried to make some myself, to no avail. Did not try the copper wire trick though. My advice is bite the bullet and order the OEM parts. This also goes for the Clutch, SLAVE, cylinder. If replaceing it order the OEM part. Also the gaskets for the crank case Side Covers. Both left and right ! Order the OEM gaskets. Also, if rebuilding the front brake Master , Order the OEM. Also, if rebuilding the Clutch, master cylinder, Order the OEM . Also, the Carb, Diaphrams !!! Forget the various GLUE, type repairs, Order new ones while they are still available, I know, they are expensive, BUT???? Anyway, that's my story, and I'm sticking to it !!
crowrod Posted August 29, 2015 Posted August 29, 2015 Will these work? http://www.ebay.com/itm/OEM-Yamaha-XVZ1300-Royal-Star-Venture-XVS1100-V-Star-Muffler-Gasket-4NK-14714-00-/361354774956?hash=item54226c49ac&vxp=mtr
DragonRider Posted August 29, 2015 Author Posted August 29, 2015 Well is says it fits XVZ1300, but I have never seen one on any of my Ventures, someone else will have to chime in on that. I will check the part number on it to see.
Freebird Posted August 29, 2015 Posted August 29, 2015 Well the part number is shown right in the listing and seems to be correct. Boats.net has them also and shows what they are supposed to fit. You posted this is the watering hole instead of either First Gen or Second Gen tech talk so I am only guessing that you want them for a first gen. That part number appears to be only for the Royal Stars and the second gen Royal Stars and RSVs. http://www.boats.net/parts/detail/yamaha/Y-4NK-14714-00-00.html
Freebird Posted August 29, 2015 Posted August 29, 2015 If you'll confirm that you are talking about the first gen, I'll move this thread to the correct forum so that others can hopefully find it later.
Prairiehammer Posted August 29, 2015 Posted August 29, 2015 (edited) Has anyone found another source other than Yamaha for the gaskets that go between the muffler and the collector. I find they want anywhere between 18.00 up to 26.00 apiece for them. That is an outrageous price for a gasket. Lewis, that muffler gasket has gone through several renditions and part numbers over the decades. Currently, the part number is 3JJ-14653-00. Before that it was 47G-14653-00. Before that it was 1L9-14714-01. AND before THAT it was 1L9-14714-00. My point is: don't limit yourself to finding just the current part number. For instance, I found NOS PN. 1L9-14714-01 on eBay for $14.99 with free shipping. Here: http://www.ebay.com/itm/New-NOS-Yamaha-1976-83-Various-1986-90-YX600-Exhaust-Gasket-1L9-14714-01-00-/171893472105?hash=item2805a63b69&vxp=mtr Edit: I found the 3JJ-14653-00 "fibrous" gasket at =custom"]Partsnmore for $8.50 each, however shipping for two was another $15+. It is in the XJ750 parts section. Scroll down the page that I linked. DonB made some of those gaskets from copper pipe. Here is a thread:http://www.venturerider.org/forum/showthread.php?38717-gaskets-for-collector&highlight=copper+exhaust Edited August 29, 2015 by Prairiehammer
syscrusher Posted August 30, 2015 Posted August 30, 2015 From RonAyers: Gasket, Exhaust 4 Item #3JJ-14653-00-00 $17.24
