Oldodge Posted April 12, 2015 Posted April 12, 2015 I added a strip of LED lights to each side of the fairing hoping to increase visibility. Not a good picture, but if I don't post a picture no one will believe it.
Zzyzx Posted April 12, 2015 Posted April 12, 2015 I have had these on my RSV for about a year and always ride with them on. I also sell these as a kit if anyone is interested.
videoarizona Posted April 13, 2015 Posted April 13, 2015 (edited) I added a strip on each side to my 1st gen two months ago. I like the look...Plus...it adds light directly in front of me when I go scooting across the desert at night.... Edited April 13, 2015 by videoarizona Add
Zzyzx Posted April 14, 2015 Posted April 14, 2015 I have received a number of PM's regarding these kits. I will post them in the classified section to help make it easy to review and order. Here is the link to my web site where they can also be purchased. http://www.tourbuddyrsv.com/Accesory-Lighting.html Thanks!
friesman Posted April 14, 2015 Posted April 14, 2015 Hi Would you happen to have a close picture of them in daylight maybe with and without the lights on? Brian I have received a number of PM's regarding these kits. I will post them in the classified section to help make it easy to review and order. Here is the link to my web site where they can also be purchased. http://www.tourbuddyrsv.com/Accesory-Lighting.html Thanks!
Zzyzx Posted April 14, 2015 Posted April 14, 2015 Here are a few pictures of the fairing LED's with and without the bike lights on.
friesman Posted April 14, 2015 Posted April 14, 2015 thanks for the pics, those look good. Looks like I may have to do a payday purchase.. Are those adhesive attached or hooked into the fairing somehow? Brian
videoarizona Posted April 14, 2015 Posted April 14, 2015 Brian, Ed can talk about his products...but I originally used the stickum that came with the lights I bought. Didn't hold well...started to sag in middle. So I tacked them on with little spots of epoxy. They will come off if you carefully pry them....seem to not hurt the plastic (don't ask). But I figure they are there to stay. So far, they have not moved. BTW, I wired mine directly to ACC circuit so they come on with bike. If I had to do it again, I would wire to battery with a switch. Reasoning...they would be great camp lights until camp is setup. They really do light up the area around the front of the bike...and the LED drain would not be enough to worry me...
aharbi Posted April 14, 2015 Posted April 14, 2015 Here are a few pictures of the fairing LED's with and without the bike lights on. the pictures were very helpful, thank you. I ordered a set of these and also the front and rear side marker LEDS from your web site. I've been looking for them for sometime now. I'll post reviews for the rest of the team when I get them.
SilvrT Posted April 14, 2015 Posted April 14, 2015 I have received a number of PM's regarding these kits. I will post them in the classified section to help make it easy to review and order. Here is the link to my web site where they can also be purchased. http://www.tourbuddyrsv.com/Accesory-Lighting.html Thanks! Not meaning to be picky; however, you might want to change the following sentence on your web site to use the correct word. "Projects more front and side angle lighting providing drivers around you better visibility of your presents." presents should be presence
Oldodge Posted April 14, 2015 Author Posted April 14, 2015 The ones in post #1 are simply led strip lights from Walmart. I did remove the adhesive from the led strips and replace it with 3M moulding tape like is used for putting moulding etc on cars. The original sagged immediately.
Zzyzx Posted April 14, 2015 Posted April 14, 2015 (edited) Thanks SilverT, DanG Spill CHeck Will make the change on the web site. As for these sticking... The glue on the strips I use is 3m sticky and mine haven't any issues coming loose for the past year plus but, if they ever do come loose I would use 3M's extreme 2 sided tape. One thing you have to do is make sure the surface is free from any wax and dirt. Another is to install these when it is warm, over 65 degrees or they may not adhere as well. Edited April 14, 2015 by Zzyzx
SilvrT Posted April 14, 2015 Posted April 14, 2015 Thanks SilverT, DanG Spill CHeck Will make the change on the web site. YVW Another is to install these when it is warm, over 65 degrees or they may not adhere as well. I just installed a pair of LED lights on my side bags. The instructions said to run your fingernails a few times over the sticky backing before removing the backing and mounting the lights. Reason was to "activate" the 3M adhesive. Never heard of this before but what the heck, .... maybe there's something to it.
Zzyzx Posted April 14, 2015 Posted April 14, 2015 Brian, The glue on the strips I use is 3m sticky and mine haven't any issues coming loose for the past year plus but, if they ever do come loose I would use 3M's extreme 2 sided tape to reattach. One thing you have to do is make sure the surface is free from any wax and dirt. Another is to install these when it is warm, over 65 degrees or they may not adhere as well. Ed
