GolfVenture Posted April 6, 2015 Share #1 Posted April 6, 2015 Does installing a K&N air filter require any slight carb setting adjustment? Link to comment Share on other sites More sharing options...
flyday58 Posted April 6, 2015 Share #2 Posted April 6, 2015 This is from the thread "Pilot screw 5 turns out" down the page: "I've been having problems with backfire thru the carbs so I did alot of reading and most say pilot screw is lean so I went 4 turn and then 5 a little better. My question is why do I have to be out so far on my pilot setting? I should mention it has a k&n air filter and the box top has been opened up quite a bit and the stock mufflers have been opened up also..." And a reply: "All of the things that you have done will each make it leaner. You will most likely need to change the main jets to get it to run right with all of those mods. Depending on just how much you have opened things up you might be able to get close by playing with the needle shims and/or the pilot. If not then either close some of the breathing back up or start playing with the main jets. These bikes do not like the airflow to be messed with. Most of the people that have messed with the airbox are now running around with patches on the air box to get back to stock airflow..." Hope this helps. There are more threads here that talk about K&N filters and such. Link to comment Share on other sites More sharing options...
RedRider Posted April 6, 2015 Share #3 Posted April 6, 2015 I made no changes to my carbs when I installed K&N filters. Pilot screws are 2.5 turns. RR Link to comment Share on other sites More sharing options...
jjven68 Posted April 7, 2015 Share #4 Posted April 7, 2015 @RedRider...I was wondering about getting that breathing system. Is it worth the money? Does it make a difference. BTW I have my pilot screws at 2.5 turns and it runs perfect Link to comment Share on other sites More sharing options...
RedRider Posted April 7, 2015 Share #5 Posted April 7, 2015 @RedRider...I was wondering about getting that breathing system. Is it worth the money? Does it make a difference. BTW I have my pilot screws at 2.5 turns and it runs perfect No, not really. I just happen to get a good deal on them when I needed to replace my original OEM. RR Link to comment Share on other sites More sharing options...
jjven68 Posted April 7, 2015 Share #6 Posted April 7, 2015 Thanks @RedRider, you saved me a good few bucks... So I guess there is no good air system worth of our money for the Ventures uh? Link to comment Share on other sites More sharing options...
XV1100SE Posted April 8, 2015 Share #7 Posted April 8, 2015 I went with the K&N filters when I needed air filters but the dealer didn't have the Yamaha filters for my RSV. Cost wasn't a whole lot more and is a one time purchase rather than based on mileage. I did no adjustment to the carbs other than a carb tune. No back fires, no lag in acceleration. Worth the price? Yes, they are more expensive than the OEM filters, but you clean and reuse them, not replace them so the purchase price is a one time thing. So, yes, they are a good investment. Link to comment Share on other sites More sharing options...
jjven68 Posted April 8, 2015 Share #8 Posted April 8, 2015 Yes, I can see where the savings could be, but considering how often filters need to be change and the fact that, at least I don't drive on dusty roads, may be I will spend the money on some more chrome...Now if the K&N would improve performance in a significant way I would definitely consider it. Now in the same subject, I also have a 01 RS Tour Deluxe I just recently acquire. Does anyone here had any experience with these: http://www.westendmotorsports.com/baron-custom-stealth-royal-star-9601-p-32211.html Link to comment Share on other sites More sharing options...
videoarizona Posted April 9, 2015 Share #9 Posted April 9, 2015 Late to the thread but I have a K&N filter system on my 1st Gen. I like the fact that I can clean it at any time, re-oil it and be back on the road. So if the Arizona dust storms get me, I can do a quick clean and oil. No running to store to buy air filters! Yea, more expensive...but the quality of the product is well known. david Link to comment Share on other sites More sharing options...
jjven68 Posted April 9, 2015 Share #10 Posted April 9, 2015 Makes sense @videoarizona...I will look around see if I can find a deal. BTW thank you for your services!!! Link to comment Share on other sites More sharing options...
