Angelo Posted November 1, 2014 Share #1 Posted November 1, 2014 I was riding home from work a couple nights ago and the bolt that bolts the shifter down fell out. I was able to get it in place to make it home, but need to replace it now. None of the dealers in town have it and not one guy could give my the specs on the bolt so I could just buy one at a parts place in town. I called yamaha and all they could tell me was shipping weight and total length but not thread pitch. Anyone either know or willing to pull and get thread pitch/length on theirs for me? Really don't want to pay $10 for a $2 bolt. Link to comment Share on other sites More sharing options...
MidlifeVenture Posted November 1, 2014 Share #2 Posted November 1, 2014 It is the same as the bolts on the side cover use one of the false ones in a pinch Link to comment Share on other sites More sharing options...
pbjman Posted November 1, 2014 Share #3 Posted November 1, 2014 It is the same as the bolts on the side cover use one of the false ones in a pinch That's a good thing to know! Link to comment Share on other sites More sharing options...
Angelo Posted November 1, 2014 Author Share #4 Posted November 1, 2014 It is the same as the bolts on the side cover use one of the false ones in a pinch Length and pitch? Link to comment Share on other sites More sharing options...
Mike G in SC Posted November 1, 2014 Share #5 Posted November 1, 2014 So, use one forward side cover bolt for the shifter. Take the other one to your hardware store to match up. But, you may end up buying the OEM bolt as it has a wider head than the others. And, on this one , use some blue Loctite. Link to comment Share on other sites More sharing options...
kevin-vic-b.c. Posted November 1, 2014 Share #6 Posted November 1, 2014 it is also the same bolt as the one holding the plastic cover trim around the fuel tank filler and I believe a few other places Link to comment Share on other sites More sharing options...
Angelo Posted November 1, 2014 Author Share #7 Posted November 1, 2014 If anyone has any doubts about spending $12 measly dollars for a membership to this forum, here is yet another thread proving this boards worth. Thanks for the help guys. Now that I think about it more, with that one bolt fitting so much stuff on these bikes, surprises me that none of these guys had it. Link to comment Share on other sites More sharing options...
M61A1MECH Posted November 1, 2014 Share #8 Posted November 1, 2014 The dealers, especially the parts guys, know less about the Venture than anyone on this board. They were forever asking me, "Is that the 1600 cc or the 1700 cc version?" or "Why do you think you need 4 spark plugs?" Chances are they have the bolt or a suitable sub in stock, but are just to ignorant to know they have it. Best option is just what has been suggested here, take one of the bolts from the plastic cover around the ingition or one from the side cover and go to ACE, Lowes or Home Depot and match it up as best you can, use blue locktit when you install it and carry a spare. Link to comment Share on other sites More sharing options...
videoarizona Posted November 1, 2014 Share #9 Posted November 1, 2014 For the past few years, I've been finding an amazing number of bolts, washers and nuts at ACE. Stainless, metric and so on. I no longer head to the dealer first....ACE down the street has been good to me!! Two scoots and a sailboat. Yep! Link to comment Share on other sites More sharing options...
Mike G in SC Posted November 1, 2014 Share #10 Posted November 1, 2014 But, Angelo, got to digress. Although a few other bolts on the bike will fit, the one for the shifter is unique. Same thread as some others but a different, larger head head. And it has more shiny. You may want to swap it with another VR rider when they are not looking. Just saying. And, that will save you $12, cause that is about what mine cost when I replaced the OEM bolt. hehe. Link to comment Share on other sites More sharing options...
Angelo Posted November 1, 2014 Author Share #11 Posted November 1, 2014 But, Angelo, got to digress. Although a few other bolts on the bike will fit, the one for the shifter is unique. Same thread as some others but a different, larger head head. And it has more shiny. You may want to swap it with another VR rider when they are not looking. Just saying. And, that will save you $12, cause that is about what mine cost when I replaced the OEM bolt. hehe. Want to meet for coffee:whistling: Link to comment Share on other sites More sharing options...
djh3 Posted November 2, 2014 Share #12 Posted November 2, 2014 If your worried about the head size, measure up what you need to cover the shifter. If its real close to what the side cover head is and you think you need more surface area, just dont cut the bolt off as short and add a SS washer. Thin one like an AN if you find it. Link to comment Share on other sites More sharing options...
Angelo Posted November 2, 2014 Author Share #13 Posted November 2, 2014 One of the bolts on the trim piece around the gas tank was perfect to match up, just needed a washer that was slightly larger in diameter. Link to comment Share on other sites More sharing options...
Midrsv Posted November 3, 2014 Share #14 Posted November 3, 2014 I lost the shifter bolt on my 2007 RSV about 200 miles from home at the start of a 4500 mile trip. Pulled off an interstate exit ramp and went to down shift and found that my shifter wasn't there. Looked down and it was on the floorboard. I managed to get it back on the pivot shaft and made it to a gas station. I took some zip tie strips and secured it the best I could. Continued on my way with no problem. A couple of thousand miles later I passed a NAPA store and decided to stop to see if I could get a replacement. I found a bolt and washer that worked and continued on. Once I got home I replaced it with the correct screw from Yamaha and made sure to use Loctite. Dennis Link to comment Share on other sites More sharing options...
