Midnight Posted April 7, 2014 Share #1 Posted April 7, 2014 Is it possible to replace the rear valve cover gasket without removing the carbs? Link to comment Share on other sites More sharing options...
RedRider Posted April 7, 2014 Share #2 Posted April 7, 2014 Yes it is. Difficult, but it can be done. Just did it this past winter when I did my valves. RR Link to comment Share on other sites More sharing options...
kentuckyrider Posted April 7, 2014 Share #3 Posted April 7, 2014 I replaced mine a few years ago. It can be done. They are kind of H shaped, I used a little black rtv on the tabs to help hold them in place. Just take your time it can be done. Mine don't leak any more. Was worth the battle of swapping them out. Link to comment Share on other sites More sharing options...
kentuckyrider Posted April 7, 2014 Share #4 Posted April 7, 2014 I am on my phone just seen you have a 07 mine is a 91 might be different Link to comment Share on other sites More sharing options...
MiCarl Posted April 7, 2014 Share #5 Posted April 7, 2014 I know someone who claims to have done valve lash on a 2nd gen without pulling the carbs. That tells me you should be able to replace the gasket with the carbs in place. Link to comment Share on other sites More sharing options...
RandyR Posted April 7, 2014 Share #6 Posted April 7, 2014 you don't need to remove the carbs Link to comment Share on other sites More sharing options...
TheKid Posted April 7, 2014 Share #7 Posted April 7, 2014 This is good news to me as I need to replace mine. Can anyone help: I have a slight antifreeze leak come from behind me cylinder covers (the ones that can be unbolted and diamond cut). i thought i read A LONG time ago about a fix for that. Does anyone know? Link to comment Share on other sites More sharing options...
Freebird Posted April 7, 2014 Share #8 Posted April 7, 2014 There are a lot of threads here about that issue. Very simple fix. Here is one thread that will get you started. http://www.venturerider.org/forum/showthread.php?t=65768 They are cheap and easy to replace but a fix that has been used by many here is to glue a dime on the inside of the fins so that they put more pressure on the existing plugs. Link to comment Share on other sites More sharing options...
RedRider Posted April 7, 2014 Share #9 Posted April 7, 2014 Order a set of replacement plugs for the next time you change plugs. Cheap and easy. RR Link to comment Share on other sites More sharing options...
