I completed the modification to my signal flasher and It works perfectly.
I cut the wire loop and inserted the 2 watt 0.33ohm resistor as instructed. The flasher now flashes correctly with the led bulbs. Pretty easy to do.
Mike
[ATTACH]82307[/ATTACH] [ATTACH]82306[/ATTACH]
  dacheedah said:
What kind of blinker fluid did you put back in her? Synthetic or dino?
Since you are doing this to convert to modern LEDs, it is obvious that you must also have modern synthetic blinker fluid. DUH!!!!!:doh::doh::doh::whistling:
Sorry Jeff, what wazzzz I thinkin
  M61A1MECH said:
Don't forgewt that LEDs are polarity sensitive, so make sure you got the forward biased DC compatible blinker fluid, the AC stuff won't work.
All I can find is Blinker + in the blue container and Blinker - in the red container
  • 1 year later...
