Dale124 Posted February 23, 2014 Share #1 Posted February 23, 2014 Hi all. I was wondering what kinds of options are out there for adding more lighting to the brake/ tail lights on my 2013 RSV. I have seen the one from Yamaha, but was wondering if that is the best option, or are there others out there I should be looking into. Thanks in advance, Dale Link to comment Share on other sites More sharing options...
dacheedah Posted February 23, 2014 Share #2 Posted February 23, 2014 Can't have too many, I have a set of led light under trunk, if you measure you can find these in a Farm & Fleet. . ., a set of Harley lights added to license plate frame, I have also seen LED's run down on the chrome on either side of the fender. Link to comment Share on other sites More sharing options...
MikeWa Posted February 23, 2014 Share #3 Posted February 23, 2014 I have aded a few led conversions. The images show the tail lights and the 4-way flasher. The turn signals and brake lights are similar. Mike [ATTACH]82251[/ATTACH] [ATTACH]82252[/ATTACH] Link to comment Share on other sites More sharing options...
Bert2006 Posted February 23, 2014 Share #4 Posted February 23, 2014 I added a couple of Bikevis. Bullet lights under the trunk, see them by following link. http://www.venturerider.org/forum/attachment.php?attachmentid=78710&d=1374664856 Since then I have also added the Harley lights like MikeWa is showing above as well as the CustomDynamics 100 light led board. All are led. Hope this helps.... Link to comment Share on other sites More sharing options...
KeithR Posted February 23, 2014 Share #5 Posted February 23, 2014 I added the LED Light Bar from Rivco http://www.rivcoproducts.com/products/product.php?productid=61&cat=398&page=1 and the 100 LED brake/Tail Light from Custom Dynamics. http://www.customdynamics.com/Yamaha_tail_retro.htm Keith Link to comment Share on other sites More sharing options...
M61A1MECH Posted February 23, 2014 Share #6 Posted February 23, 2014 Here is what mine looks like, I have added the 100 LED board from Custom Dynamics, a LED bar from R&P Carriages under the trunk, Harley Tail Lights and a couple of high out put LEDs from R&P Carriages. The brake lights are on a modulator that flashes 3 or 4 times and then goes solid for a period and then starts the flash cycle over again. I also added a diode net work for the light bar so the left or right segments on the light bar flash with the turn signals. http://s40.photobucket.com/user/royalsteve/library/VENTURE%20REAR%20LIGHTING If you decide on a set of lights to add, I sell a plug in "T" harness that will let you tap into the tail light circuits with out having to cut into the harness, see my add in the classifieds under member vendors. Link to comment Share on other sites More sharing options...
Guest tx2sturgis Posted February 23, 2014 Share #7 Posted February 23, 2014 The stock RSV tailight is lousy. It doesnt have a reflector around the bulb to focus light to the rear. You cant go wrong with the Custom Dynamics LED module. Link to comment Share on other sites More sharing options...
Squidley Posted February 23, 2014 Share #8 Posted February 23, 2014 http://www.tractorsupply.com/en/store/blazer-led-low-profile-id-and-stop-tail-turn-light-bar-over-80-in Link to comment Share on other sites More sharing options...
