Marcarl Posted July 3, 2013 Share #1 Posted July 3, 2013 I am working on an 84 Venture. The fuel pump keeps pumping, so it's not building any pressure, so I took it off. It clicks just fine, so I opened up the pump side to see what was happening. I noticed two check valves, one with a rubber center and one without. Does any body know what should be there, and if there is a rebuild kit available? Link to comment Share on other sites More sharing options...
dingy Posted July 3, 2013 Share #2 Posted July 3, 2013 See thread below for fuel pump dissected. http://www.venturerider.org/forum/showthread.php?t=63062 Gary http://i1007.photobucket.com/albums/af193/gdingy101/searchuseit_zps7a60934a.jpg Link to comment Share on other sites More sharing options...
Marcarl Posted July 3, 2013 Author Share #3 Posted July 3, 2013 All right,, I did, and didn't come up with that thread,,,, but it's what I needed,, thanks! Now the next question, which you didn't answer in that thread either, but maybe this time,,,,,,is there a rebuild kit? Link to comment Share on other sites More sharing options...
BradT Posted July 3, 2013 Share #4 Posted July 3, 2013 All right,, I did, and didn't come up with that thread,,,, but it's what I needed,, thanks! Now the next question, which you didn't answer in that thread either, but maybe this time,,,,,,is there a rebuild kit? Guess you didn't use it right. HE had a rebuilt kit on the paper, did you not see it.. Brad Link to comment Share on other sites More sharing options...
dingy Posted July 3, 2013 Share #5 Posted July 3, 2013 All right,, I did, and didn't come up with that thread,,,, but it's what I needed,, thanks! Now the next question, which you didn't answer in that thread either, but maybe this time,,,,,,is there a rebuild kit? I have never come across a rebuild kit for fuel pump for a Venture. Don't feel bad about the search not finding thread. I couldn't find it directly myself, found it linked in another thread that Google search pointed to. Just never got to use that picture on someone that I thought might take it personally. Gary Link to comment Share on other sites More sharing options...
Marcarl Posted July 3, 2013 Author Share #6 Posted July 3, 2013 Guess you didn't use it right. HE had a rebuilt kit on the paper, did you not see it.. Brad Guess you need some more schooling,,,, did you move too far away from Swifty? That was the old parts you were looking at, not new ones......dudhhh! Link to comment Share on other sites More sharing options...
Marcarl Posted July 3, 2013 Author Share #7 Posted July 3, 2013 I have never come across a rebuild kit for fuel pump for a Venture. Don't feel bad about the search not finding thread. I couldn't find it directly myself, found it linked in another thread that Google search pointed to. Just never got to use that picture on someone that I thought might take it personally. Gary Thanks, I haven't been able to come up with one either. Any idea who makes it? And the picture? Your time is coming,,, if I can only find the right 'picture'! Link to comment Share on other sites More sharing options...
Condor Posted July 3, 2013 Share #8 Posted July 3, 2013 Link to comment Share on other sites More sharing options...
Keemez Posted July 3, 2013 Share #9 Posted July 3, 2013 This post ( http://www.venturerider.org/forum/showpost.php?p=700962&postcount=29 ) is in a thread started by you on a related issue. The two check valves work in tandem. One is an inlet, one is an outlet. That way the pump will let fuel in through the in line but not back out except by way of the out line (and vice versa). I got fed up with the OEM pump last fall and put a Mr. Gasket on mine. ........ and now my mileage has decreased noticeably but I'm tired enough of farting with it that I'm gonna leave it. I am working on an 84 Venture. The fuel pump keeps pumping, so it's not building any pressure, so I took it off. It clicks just fine, so I opened up the pump side to see what was happening. I noticed two check valves, one with a rubber center and one without. Does any body know what should be there, and if there is a rebuild kit available? Link to comment Share on other sites More sharing options...
reddevilmedic Posted July 3, 2013 Share #10 Posted July 3, 2013 mr. gasket. I got mine for like 24 bucks at summit. Link to comment Share on other sites More sharing options...
Prairiehammer Posted July 3, 2013 Share #11 Posted July 3, 2013 Any idea who makes it? It is a Mitsubishi. Used on several different motorcycle brands. Only mountings vary. Link to comment Share on other sites More sharing options...
Black wing Posted July 3, 2013 Share #12 Posted July 3, 2013 i have an old pump with good diaphragms if you want the diaphragm block Link to comment Share on other sites More sharing options...
