Hi All I have a suspension pump for my RSV. I think im using it wrong. I put the air into the shock however when I go to unscrew the pump im to slow and all the air rushes out. What is the trick to unscrewing the pump without losing all the air. I pump the rear shock up to 47 and by the time i got the chuck undone it measured out to 42.5 lbs. Im only pumping the fronts up to 7lbs to scared of blowing the bladders but by the time i get it undone im down to 0lbs. Any advice.
Thanks in advance
Vince
What kind of suspension pump do you have? Most of us use the "Progressive" brand pump and it has a zero loss chuck. If that is what you have, you should not be losing much, if any, air when you remove it.
ok. Ill see if my neighbor knows tomorrow then probably get a progressive. Looking forward to your maintence day in June.
  • 3 weeks later...
This is the one I got at local Harley dealer.
that is the one I bought last weekend.... works great but now I gotta learn to ride again, PO had just used a bicycle pump and pressures were all screwy.
The pump i have is the right one. I found out operator error was happening. I hate that when it happens:rotf:
So tell us how you could possibly screw that up :stickpoke::stickpoke: Inquiring minds want to know.:stirthepot:
