gunboat Posted February 8, 2008 Share #1 Posted February 8, 2008 hi all could anyone tell me at what milage should you change the u-joint on my '99 rsv? i have over 42,000 miles on mine, it seamed ok when i pulled the rear end, driveshaft and swingarm off and greased everything a couple of months ago. fixen to put about 2,ooo miles on it next weekend and will to going to the international rally in july. just rather change it now than on the side of the road. thanks in advance don Link to comment Share on other sites More sharing options...
Rick Butler Posted February 8, 2008 Share #2 Posted February 8, 2008 Don, Until it starts making a clunking noise in the area of the middle gear, I wouldn't worry about it. The needle bearings are sealed and until they wear out there is really nothing you need to do. If it starts making a clunking noise on decelleration or accelleration you can verify it by taking the rear wheel off the ground and then move the wheel back and forth where you should feel it. And it's not a easy job because at a minimum the entire swing arm must come out. I did one on a 93 and it wasn't fun where I had to come with some creative solutions to get it replaced. I think the manual requires you to remove the engine to replace it? I've got over 90k on my 2002 and it's still doing fine. There you have MHO, Rick Link to comment Share on other sites More sharing options...
gunboat Posted February 8, 2008 Author Share #3 Posted February 8, 2008 hi rick thanks for the fast reply, hope the engine won't have to come out when it's time to replace it. was hopeing to do it myself, will have to break out the shop manuel and read up on it. thanks again don Link to comment Share on other sites More sharing options...
Squidley Posted February 9, 2008 Share #4 Posted February 9, 2008 Don, As long as you keep it properly lubed you will more than likely never have issues with it. They Rarely go bad and that I'm sure is from major abuse. I wouldn't even think twice about it and Rick has shared all the advise that you need to know if problems do arise:happy34: Link to comment Share on other sites More sharing options...
