jjj7s Posted September 14, 2012 Posted September 14, 2012 Hi all: Any chance anyone has had a problem with the passenger intercom. The radio/CB work fine and can be heard in the drivers headset fine. However, the passenger hears nothing. The two shops I use were of no help, didn't want to try to figure it out and pretty much sai I was on my own. Anyone have any thought where I might begin in trying to resolve this issue? Thanks
Trader Posted September 14, 2012 Posted September 14, 2012 sigh.....update your details or signature or at least tell us what kind of bike you have the problem with. Saves us having to look at your profile .....to see you ride a 2nd Gen Sorry....I can't help you with them new fangled devices.
GeorgeS Posted September 14, 2012 Posted September 14, 2012 First thing I would do, is , find, open, and clean ALL the connectors for the Entire Audio system. From the Rear control panel, follow the the Cable, somplace under the passenger seat you should find a " DIN " connector, I would suspect that might be loose, or the pins need cleaning. Go to the Radio, amplifier unit, reomove, and clean all plugs and connectors, Use electrical contact cleaner on all male and female pins. ( get some CRC brand electrical contact cleaner, most auto parts stores carry it. ) I would suspect a Loose connector someplace in the system.
jjj7s Posted September 14, 2012 Author Posted September 14, 2012 GeorgeS, Sounds like a good place to start and I will give it a try tomorrow. Keep you fingers crossed I find something!!!!. Thanks...enjoy the weekend!!!!
etcswjoe Posted September 14, 2012 Posted September 14, 2012 I agree with George, about the cable under the passenger seat/trunk I pulled mine lose doing maintenance on the trunk. I am sure you made sure the volume was turned up.
