af226 Posted August 13, 2012 Share #1 Posted August 13, 2012 My 85 temp gauge has stopped working. Fan still starts when the bike heats up so everything is working except the actual gauge. Is there a cost effective/easy fix. Seem that all the wires are there and attached. Thanks. Link to comment Share on other sites More sharing options...
dingy Posted August 13, 2012 Share #2 Posted August 13, 2012 It could either be the gauge or the sender. The sender is located on right front side of motor. If you remove the radiator side guard you should be able to see it. There are two senders in the radiator hose junction tubing. One is for the fan and other is for gauge unit. Gauge unit has a Green with Red tracer wire going to it. Fan sender is a Blue with Green tracer. Either of these sensors can be shorted to ground on the connecting wire side to with no bad effects. The gauge sensor should cause the gauge to go full scale, the fan on will turn the radiator fan on. Both need the key on to do this. Gary Link to comment Share on other sites More sharing options...
GaryZ Posted August 13, 2012 Share #3 Posted August 13, 2012 As Dingy said, there are two senders in the top radiator hose. One is for the temperature gauge and the other turns on the cooling fan. It is possible the temperature gauge sender is unplugged. Ask me how I know about this . . . Link to comment Share on other sites More sharing options...
friesman Posted August 13, 2012 Share #4 Posted August 13, 2012 My 85 temp sensor lead has come off once as well, simple to reconnect like Gary says. Brian Link to comment Share on other sites More sharing options...
PBJ Posted August 13, 2012 Share #5 Posted August 13, 2012 Timely thread the temp guage on my 86 stopped working too. Plus i need to check the vacuum on the No.2 cylinder cause it got hot the other day and the idle started to go up again. Still haven't worked out all the bugs from my new girl. Link to comment Share on other sites More sharing options...
Yammer Dan Posted August 13, 2012 Share #6 Posted August 13, 2012 Probally as said just replug. Tighten those plugs up a little. Just squeeze a little with needle nose. Not too much!! Link to comment Share on other sites More sharing options...
af226 Posted August 13, 2012 Author Share #7 Posted August 13, 2012 Thanks. Going to look now:) Link to comment Share on other sites More sharing options...
GaryZ Posted September 3, 2012 Share #8 Posted September 3, 2012 Thanks. Going to look now:) Did you get it working??? Link to comment Share on other sites More sharing options...
af226 Posted September 7, 2012 Author Share #9 Posted September 7, 2012 Yup...the green wire was off. A little squish and all is good. THANKS ALL!! Link to comment Share on other sites More sharing options...
