GolfVenture Posted October 29, 2011 Posted October 29, 2011 Anyone know where one can get stainless steel or chrome channeled U shape long bracket (The U channel be 1 in X 1 in X 1 in and about the length of the rear trunk mount) where it could be mounted under the far rear of the trunk mount so the open end is to the front on the bike and the closed end is facing the rear of the bike where I could install from Custom Dynamics Sequential Amber LED Turn Signals on the ends and in the center a Custom Dynamics LED Stop Lamp. Then under the bracket I could install a couple of white lights hooked to a push switch where I can get the attention of cagers approaching dangerously. Even an L shape bracket would work. Or maybe someone has a good suggestion as to where one could mount the lights described, except drilling into the plastic trunk for an MKII.
Gary N. Posted October 29, 2011 Posted October 29, 2011 Any good sheet metal shop should be able to bend it up for you to your specs.
Eck Posted October 29, 2011 Posted October 29, 2011 Lowe's / Home Depot has L angle and channel. Sorry, niether will be Chrome or SS.. Suggeestion: Check out the bathroom hardware section for a chrome L angle or part that may work. If you choose the L angel or "U" channel idea here are some helpful install instructions. Cut the L angle or U channel to your aquired length. Locate (twice), mark, inspect then complete any required drilling, deburr Inspect again for proper alignment and location of each part Lightly abraid the surfaces of both part using 180 grit or finer abrasive Clean Cover with (2) coats of grey primer on each item, dry over night. Cover with (20 coats of black (or chrome), dry over night. Install Locate lights and cover them.. Have fun.. Eck
GolfVenture Posted October 29, 2011 Author Posted October 29, 2011 I had to check your profile Eck. Yep an Engineer and worked for Boeing / Airbus and in SC. Made me want to cry, felt like I was at work again. Try to forget about work on the weekends. Oh wait I have to go in today and tomorrow.
Gary N. Posted October 29, 2011 Posted October 29, 2011 If going the stainless steel route beware. It's real hard to work with. Tough on cutting tools and drill bits. If you're only drilling a few holes then not too bad. You can get mirror finish and polished SS sheet metal. Aluminium can be polished to look close to chrome and is much easier to work with. It will tarnish in time so a coat of clear urethane or lacquer will help to keep it shiny longer.
Black Owl Posted October 30, 2011 Posted October 30, 2011 Ckeck www.McMaster.com They shoud have what you are looking for.
Trader Posted October 30, 2011 Posted October 30, 2011 I tried to order thru McMaster and never got any response...twice! Maybe they just ignore Canadian orders???
friesman Posted October 30, 2011 Posted October 30, 2011 I tried to order thru McMaster and never got any response...twice! Maybe they just ignore Canadian orders??? Yes, mcmaster ignored me twice as well, i called and got told they dont do Canadian orders. What bugged me was that I went thru the whole procedure credit card and all, with no response....why not just a note on the website so I dont waste my time and send my info over the net....it just screams bad customer service. Brian
