Mikealiasmike Posted June 29, 2011 Share #1 Posted June 29, 2011 (edited) Anybody know how much of a drop I need for water to drain properly on a cement porch. Right now I'm looking at 4" over a 12 foot span. Haven't poured yet, just framing it Edited June 29, 2011 by Mikealiasmike more info Link to comment Share on other sites More sharing options...
utadventure Posted June 29, 2011 Share #2 Posted June 29, 2011 Most of the contractors I've worked with did 1 to 1 1/2 inches for 10 feet. Four inches on 12 feet should be more than enough. A lot of it is based on usage. You would want to be more aggressive on an exposed patio and less on a covered porch. Dave Link to comment Share on other sites More sharing options...
eusa1 Posted June 29, 2011 Share #3 Posted June 29, 2011 i did 3 inches if fall in an 11 foot pad, and it works perfectly fine. mike Link to comment Share on other sites More sharing options...
jer878 Posted June 29, 2011 Share #4 Posted June 29, 2011 If I remember correctly 1/8in per foot Link to comment Share on other sites More sharing options...
Marcarl Posted June 29, 2011 Share #5 Posted June 29, 2011 just make sure you sloop it away from where you want the water not to be,,,,, ya that's kind of important! Link to comment Share on other sites More sharing options...
Sylvester Posted June 29, 2011 Share #6 Posted June 29, 2011 1/4"/ft. is what most slabs require. If you get less than that you will have ponding since it is hard to get the fininsh that close and still keep fall. I spent nearly 50 years in heavy highway construction. Link to comment Share on other sites More sharing options...
slipstreamer Posted June 29, 2011 Share #7 Posted June 29, 2011 1/4"/ft. is what most slabs require That is the number that I have always read for decks. Should be the same for concrete I would think. Link to comment Share on other sites More sharing options...
cecdoo Posted June 30, 2011 Share #8 Posted June 30, 2011 1/4"/ft. is what most slabs require. If you get less than that you will have ponding since it is hard to get the fininsh that close and still keep fall. I spent nearly 50 years in heavy highway construction. :sign yeah that::sign yeah that: Link to comment Share on other sites More sharing options...
Mikealiasmike Posted June 30, 2011 Author Share #9 Posted June 30, 2011 Well, if 1/4" is whats the common number here then I did good. 3" drop over 12' Appreciate all the responses. It's all framed in and looking to Fri or Sat to pour. Even got another area ready to accept the overage I always seem to have in front of cave making it easier to get bike out. I hear thats important lol. Thanks again everybody. God Bless and ride safe. Mike Link to comment Share on other sites More sharing options...
Yammer Dan Posted June 30, 2011 Share #10 Posted June 30, 2011 Looks like I'll be pouring about 9 Yrds fri or sat if workers show up. Good luck with yours. Link to comment Share on other sites More sharing options...
