reddevilmedic Posted June 23, 2011 Posted June 23, 2011 ive installed h.i.d. and led's. someone please send me pics of how to use jumpers on the cmu to correct the idiot lights. thans. i have to solder the CLASS so i might as well get the cmu out again.
Condor Posted June 23, 2011 Posted June 23, 2011 ive installed h.i.d. and led's. someone please send me pics of how to use jumpers on the cmu to correct the idiot lights. thans. i have to solder the CLASS so i might as well get the cmu out again. This is just a guess but maybe an inline resistor is needed to make up for the difference in electrical draw?? There's several tech articles on how to solder the CMU if the red light was a problem before you did the mod.
Flyinfool Posted June 23, 2011 Posted June 23, 2011 These should get you started. http://www.venturerider.org/forum/sh...3&postcount=10 http://www.venturerider.org/forum/sh...5&postcount=11 http://www.venturerider.org/forum/sh...ad.php?t=33285
reddevilmedic Posted June 23, 2011 Author Posted June 23, 2011 ok, so in the first post: i solder 4 jumpers to the areas pointed out? i have hids and leds.
Flyinfool Posted June 23, 2011 Posted June 23, 2011 Yup. There is a coil of wire with a glass component running thru the inside of the coil. It is that glass component that you are soldering a jumper across. While you are there, add just a tiny bit of solder the the solder joints at each end of the coils. these solder joints are known to break over time. Also I looked at all of the solder joints on the boards with a magnifying glass to look for any that might be starting to crack. I did not find any on mine.
