How does one remove the sticker put on the gas tank on a new bike warning about wearing a helmet? I tired with my finger nail but its on very well. I certainly do not wish to scratch the paint trying to remove it. Thank you in advance for the help.
I used Goo-Gone on mine, soaked a rag in it and just kept at it, your right they do not come off easy..
Good luck
K
Old plastic bank card followed by Goo-Gone for the adhesive residue. Plenty of elbow grease required.
Warm it up with a heat gun. It'll peel right off all in one piece very easily, no elbow grease required. A little mineral spirits will clean up the remaining residue.
I used a "razor blade" scraper but I wouldn't recommend that unless you've had lots of experience using one. I have and I still managed to nick the paint.
A heat gun is the best way to remove decals. I used my wife's blow-drier to take the huge "Ninja" decal off of the sides of my first ZX11D.
:080402gudl_prv:
I used a hair dryer and WD-40 to get mine off back in 2007 when I purchased my Venture.:cool10:
Boomer....who sez any more labels/decals will now be removed by pygmies who enjoy eating those darn things.:whistling:
I know ALOT of elbow grease will be required. I will try a hair dryer that sounds at least non chipable. Thank you all for the suggestions.
:fingers-crossed-emo
  • 4 weeks later...
As Pegscraper said. A heat gun will aid in sofenting the gulue and peel off very easy.
This will also work for any emblems that are glued on.
My badges came off with a lil heat and a 10lb fishing line.
I have used Goo-Gone and it was OK but Turrle Wax makes a sticker and label remover that works/worked a lot better for me. Walmart has it and it (auto section), in a spray can and if I remember correctly it is cheaper than Goo-Gone.
  • 2 weeks later...
