shikano53 Posted November 27, 2010 Posted November 27, 2010 Could anyone please tell me what size of dowel or plug is required to block off the AIS systems? I have read the articles but not sure what size plug is required. Thank you in advance Chris
Freebird Posted November 27, 2010 Posted November 27, 2010 I didn't remember but did a search and found this posted by Ruffy. If you go to a larger auto parts store, there is an aisle that contains carded auto parts called HELP! Its usually packed in a carded red sealed package. The HELP! section carries small and hard to find OEM parts. Look for 5/8" water pump and/or heater hose caps. Those caps are used to block off those particular orfices. The outside diameter is 3/4 and fits perfectly inside the AIS hose. I had to "lube" the cap with liquid soap to get it to fit inside the hose.
Art708 Posted November 27, 2010 Posted November 27, 2010 I didn't remember but did a search and found this posted by Ruffy. If you go to a larger auto parts store, there is an aisle that contains carded auto parts called HELP! Its usually packed in a carded red sealed package. The HELP! section carries small and hard to find OEM parts. Look for 5/8" water pump and/or heater hose caps. Those caps are used to block off those particular orfices. The outside diameter is 3/4 and fits perfectly inside the AIS hose. I had to "lube" the cap with liquid soap to get it to fit inside the hose. Can't you just cap the vacuum tubes on the carbs and render the AIS inoperable? Wouldn't that save a lot of work...if one wanted the AIS to not work.
shikano53 Posted November 27, 2010 Author Posted November 27, 2010 Thank you for the information folks. I will go to CTC and see what I can find. Kind regards for your answers Chris
Chiro Posted December 3, 2010 Posted December 3, 2010 I used a 3/4 inch dowel rod about 1 inch long. Works good.
steamer Posted December 3, 2010 Posted December 3, 2010 You can get rubber plugs at lowes.Thats where I found them.
Eck Posted December 3, 2010 Posted December 3, 2010 You better hope V7Goose doesn't see this thread on plugging the AIS system.. Oh heck,, I'm getting out of here now..
craigatcsi Posted December 3, 2010 Posted December 3, 2010 First, what is the AIS? Second, what is to be gained by plugging it?
Eck Posted December 3, 2010 Posted December 3, 2010 (QUOTE): First, what is the AIS? Second, what is to be gained by plugging it? http://www.venturerider.org/forum/showthread.php?t=485
Kirby Posted December 3, 2010 Posted December 3, 2010 Instigator!!!!! Eh, er, Yepper!!!! Still waiting!!!
footsie Posted December 9, 2010 Posted December 9, 2010 Eh, er, Yepper!!!! Still waiting!!! I'm just waiting, know is coming Gregg
