Rick Haywood Posted August 11, 2010 #1 Posted August 11, 2010 I have a 2000 Venture that is new to me and I was wondering (since I have no owners manual) What lights come on when You turn on the key. Mine only has the yellow check engine light come on for a few seconds then when I kit the starter 2 red lights one each side on the bottom come on while starting it.Should there be other lights come on when the key is on? Also I noticed 2 times in the 4,000 miles I have put on the bike that when it was really hot and I had a tail wind the yellow check engine light came on very faintly so faintly that at first I wasn't sure if itwas on or if it was the sun. Does this light let you know it is getting a little warm or what? Thanks for the help. I am sure I will get everything figured out with you alls help Rick
Rick Haywood Posted August 11, 2010 Author #2 Posted August 11, 2010 Rick Haywood said: I have a 2000 Venture that is new to me and I was wondering (since I have no owners manual) What lights come on when You turn on the key. Mine only has the yellow check engine light come on for a few seconds then when I kit the starter 2 red lights one each side on the bottom come on while starting it.Should there be other lights come on when the key is on? Also I noticed 2 times in the 4,000 miles I have put on the bike that when it was really hot and I had a tail wind the yellow check engine light came on very faintly so faintly that at first I wasn't sure if itwas on or if it was the sun. Does this light let you know it is getting a little warm or what? Thanks for the help. I am sure I will get everything figured out with you alls help Rick I was told to add pictures of my bike so here they are
FuzzyRSTD Posted August 11, 2010 #3 Posted August 11, 2010 Very nice bike Rick. I think there is a owners manual on this site somewhere. Some one that is more familiar with your bike will help you I am sure. I have a 2007 Royal Star Tour Deluxe. Again you have a very nice bike, and welcome to the club.
DONATALIE Posted August 11, 2010 #4 Posted August 11, 2010 (edited) Rick, I also have a 2000 RSV, the two-tone red one, not the white millenium edition like yours. I just went out and checked my dash board while turning on the ignition. Mine does EXACTLY what you described, and its been running great since I bought it used in 2007. Fortunately, mine came to me with the owner's manual. Unfortunately, it does not tell you anything in the single paragraph addressing the Check Engine Light. It just tells you to take it to the dealer. Bear in mind that I am not a mechanic, but two of my brothers are auto mechanics. One of them is sitting here watching the Phillies game with me now. He says that based on what you described your problem is most likely either the radiator cooling fan, sensor, and/or coolant level. He STRONGLY suggests that if you aren't sure, get it to the dealer. They should be able to plug a small, hand-held computer into your bike, which will give them a diagnostic code that will tell them where to look. Obviously, those computers aren't cheap, so be prepared to pay for it. But it might be worth the money if they can find what's wrong (or isn't). Hope this helps. Don Edited August 11, 2010 by DONATALIE
Rick Haywood Posted August 11, 2010 Author #5 Posted August 11, 2010 (edited) Feets said: Try this link for both owner's and service manuals: www.venturerider.org/forum/showthread.php?t=1828 Welcome to the group! Feets, Thanks for the link. In just a minute or two I did find out I have a clock on the dash and also how to get it to display and how to set it, Cool Thanks again Also that is a picture of my 78 wing and my Venture Edited August 11, 2010 by Rick Haywood added something
RedRider Posted August 11, 2010 #6 Posted August 11, 2010 Rick, There are no on-board troubleshooting codes available on this bike. The idiot lights are all you get. When it is hot and you stop, can you hear the fan going (yes, you will need to turn the bike off to hear it - but keep the key in the RUN position)? If not, your fan may not be working properly (fuse, temp sensor, or fan motor). Check in the Technical Library for troubleshooting. There are both the owner's manual and a complete Yamaha Repair Manual on line here. Both are pretty big files. RR
eusa1 Posted August 11, 2010 #7 Posted August 11, 2010 rick! welcome and hello from Dixon Illinois! did i see you on rt 39 last week in Peru?
Rick Haywood Posted August 11, 2010 Author #8 Posted August 11, 2010 RedRider said: Rick, There are no on-board troubleshooting codes available on this bike. The idiot lights are all you get. When it is hot and you stop, can you hear the fan going (yes, you will need to turn the bike off to hear it - but keep the key in the RUN position)? If not, your fan may not be working properly (fuse, temp sensor, or fan motor). Check in the Technical Library for troubleshooting. There are both the owner's manual and a complete Yamaha Repair Manual on line here. Both are pretty big files. RR I have never been able to hear the fan but then again how do I know if it's hot enough to kick the fan on? When I stop I normally hit the kill switch and have never really payed attention to see if I can hear it but I will start paying attention. Does anyone know if a light comes on if it does get hot?
Rick Haywood Posted August 11, 2010 Author #9 Posted August 11, 2010 eusa1 said: rick! welcome and hello from Dixon Illinois! did i see you on rt 39 last week in Peru? Yes you probably did. I don't remember what day it was but I went up to JC whitney to get a mount for my Sirius radio. I believe it was Thursday. What did we do pass each other?
eusa1 Posted August 11, 2010 #10 Posted August 11, 2010 i had just left jcw and went to Oglesby for a rootbeer, we passed on the big bridge
eusa1 Posted August 11, 2010 #11 Posted August 11, 2010 i know most of the members in this area, and several with the mm like yours, but i knew that your was not one of them. lets get together for a rootbeer sometime.
Rick Haywood Posted August 11, 2010 Author #12 Posted August 11, 2010 eusa1 said: i know most of the members in this area, and several with the mm like yours, but i knew that your was not one of them. lets get together for a rootbeer sometime. Sounds great just name the time and locations and I'll meet you there. I am semi retired at this point so anytime works
eusa1 Posted August 11, 2010 #13 Posted August 11, 2010 howz thursday looking for ya this week? i see your also a verizon customer, the calls are free 81five 44zero 028seven mike.
Rick Haywood Posted August 11, 2010 Author #14 Posted August 11, 2010 Thursday's great. I just need to be back in Eureka by 5:00 pm because I go on a Ice Cream ride with our local GWRRA chapter on Thursdays and I am taking my daughter this time since see is headed off to College and wont be able to see them for awhile, we usually have anywhere from 12 to 18 bikes go. Call me and lets set up a time and place. Three O Nine dash too 6 four dash 5 six O six Talk Later Rick. PS Great board seems like family and I have made new friends already. Thanks everyone:dancefool:
