rumboogy Posted May 4, 2010 Share #1 Posted May 4, 2010 Thanks to Freebird for an EXCELLENT pictoral and instructions regarding moving the fairing. I am about to do this myself so I can upgrade my Zumo 660 to the Zumo 665. Again, I appreciate the detailed instructions and I only have a couple of minor questions since the original instructions were written by Freebird in 2006. My first question is the 2 allen bolts size. I think they are 5mm, but I'm not for sure until I get some "ball end" allen wrenches. So are these bolts 5mm? My second question or request is for any additional tips for splitting the fairing or things that I should look for while the fairing is off. Thanks again for the great information. Wally Link to comment Share on other sites More sharing options...
Tom Posted May 4, 2010 Share #2 Posted May 4, 2010 (edited) Make sure the windshield mounting bracket is BOLTED on in the middle..Ive seen several that have plastic tiewraps holding the mount bracket on..Mine was one of them.You will notice it if it has the ties,very obvious.(Part is #7 on this exploded view that I am talking about) http://webservices.motorsportdealers.com/parts/partImages/YAM/2/MCY/2004/XVZ13TFMS_TFMSC/IMAGES/COWLING_1.Gif Edited May 4, 2010 by Tom added picture breakdown Link to comment Share on other sites More sharing options...
Bubber Posted May 4, 2010 Share #3 Posted May 4, 2010 I would suggest that if you have passing lights and still havn't installed the spacer to move the mount out and down a little that this would be a great time and a great addition to you bike. An extra set of hands to hold the fairing in place while taking out the last bolts is highly recommended. Go slow and cver the fender with a towel (a couple of towels) Steve aka Bubber Link to comment Share on other sites More sharing options...
SilvrT Posted May 4, 2010 Share #4 Posted May 4, 2010 An extra set of hands to hold the fairing in place while taking out the last bolts is highly recommended. If you make the last bolt the one at the bottom of the headlight, you can hold the fairing shell yourself with one hand while removing the bolt with the other. When re-installing, make sure the tabs on the inside edge don't get mis-aligned. Look at the edge where the outer and inner fairing shells come together. There should not be any "crack" and the outer shell should fit nicely overlap ... look closely at this before you remove the fairing, you'll see what I mean. It should be the same when it goes back together. If not, one or more of the alignment tabs are mis-aligned. Link to comment Share on other sites More sharing options...
SteveP Posted May 4, 2010 Share #5 Posted May 4, 2010 An ounce of prevention while you have it open: you should put some diaelectric grease on the plugs for the intercom/CB/audio system. You'll see the bunch of them under a large zip tie just to the throttle side of the headlight. Link to comment Share on other sites More sharing options...
Proud Dad Posted May 5, 2010 Share #6 Posted May 5, 2010 Bubber, tell us more about the spacer. Seen one in a picture here on the forum. Would make taking things apart in the future a little easier. Where can we get them. Thanks Link to comment Share on other sites More sharing options...
wes0778 Posted May 5, 2010 Share #7 Posted May 5, 2010 Thanks to Freebird for an EXCELLENT pictoral and instructions regarding moving the fairing. I am about to do this myself so I can upgrade my Zumo 660 to the Zumo 665. Again, I appreciate the detailed instructions and I only have a couple of minor questions since the original instructions were written by Freebird in 2006. My first question is the 2 allen bolts size. I think they are 5mm, but I'm not for sure until I get some "ball end" allen wrenches. So are these bolts 5mm? My second question or request is for any additional tips for splitting the fairing or things that I should look for while the fairing is off. Thanks again for the great information. Wally This is the set of "ball" wrenches I use... [ATTACH]44746[/ATTACH] [ATTACH]44747[/ATTACH] I'm probably wrong, but best I remember the 8 fairing screws take a 3mm wrench. The 2 passing light mounting bolts take 5mm. Link to comment Share on other sites More sharing options...
