surf52 Posted February 24, 2010 Posted February 24, 2010 has anyone found a way to upgrade the stereo system on rsv?
rumboogy Posted February 24, 2010 Posted February 24, 2010 That's the $64,000 question...and the money ain't been given away yet!!
Cougar Posted February 24, 2010 Posted February 24, 2010 The only up-grade I did was to place an amp in my trunk seems to help. There is a write-up I did on it in the Vtech Section. Trust me I have tried ALL the speakers and still nothing is any better then the Polk 401's (YET)! not I still will not give up on this project. I was able to get the two 5x10 retro sounds into my fairing but the sound still sucked! Now you keep looking for us will ya? Jeff
kwisor Posted February 24, 2010 Posted February 24, 2010 hello i have tryed the amp upgread removed it i have put a equlizer in the tape deck spot removed it the best thing i have done i put a edset on the head set and use a bose earbuds and i can listen to the best sound in my helment at any speed and i use a ipod touch with 2700 songs bumble bee kevin wisor 1999 rsv jax fl
Freebird Posted February 24, 2010 Posted February 24, 2010 I agree with Kevin and tried the same things. I finally gave up after finding the Edsets.
Whitlow Posted February 25, 2010 Posted February 25, 2010 Someone fill me in on the Edsets what are they where can I get them etc? Thanks
Freebird Posted February 25, 2010 Posted February 25, 2010 http://www.edsets.com They are the best I have used. I like the speakers they come with but they also have a jack where you can plug in earbuds if you prefer.
Guest scarylarry Posted February 25, 2010 Posted February 25, 2010 http://edsets.com/ All I know is what I read here..Never use them
camos Posted February 25, 2010 Posted February 25, 2010 Trust me I have tried ALL the speakers and still nothing is any better then the Polk 401's (YET)! not I still will not give up on this project. I was able to get the two 5x10 retro sounds into my fairing but the sound still sucked! Now you keep looking for us will ya? Jeff Perhaps the problem is not so much the speaker but the enclosure. Putting a sound deadening foam around and behind the speaker can help get betterr sound out the front by reducing the bad sound from the fairing enclosure. Try some pillow foam which might work ok. Another thing that can affect the quality of sound from a speaker is using minimum 16 gauge wire rather than the 22 gauge wire that often comes in systems.
Cougar Posted February 25, 2010 Posted February 25, 2010 Yep, even tried the foam behind them. ( a tad better ) added heaver wire when I installed the amp.
KiteSquid Posted February 25, 2010 Posted February 25, 2010 IMHO the best way to improve the sound from the Clarion stereo installed in these bikes is to sell the RSV and buy a new Honda Goldwing. I will not be doing this upgrade.
outlawauto38 Posted February 25, 2010 Posted February 25, 2010 i have the polk 401s with bass blockers and boom mats on all 4 speakers. bazooka made a plug and play amp and speaker kit for the rsv i was gonna try but, last i heard got2mnytoys had one but wasnt having very good luck with it. maybe you can ask him if he ever got the bugs out of it. i would go with the polks for shure, i tried another brand but they sounded worse than stock. i was trying to do it cheaper but ended up going with the polks anyway and really like them, but, you can only get so much out of a 4 inch speaker. if you do it i would put in the boom mats and base blockers in since you will allready have it apart, every little bit helps.
Bummer Posted February 25, 2010 Posted February 25, 2010 The biggest problem with the Polks is that they can handle a lot more wattage than the stock speakers, so the stock amp has a bit of trouble driving them. My current stereo related quest is to find an amp that will fit where the cassette goes. Something around 60 watts per channel. That way the stock stereo acts as a pre-amp with the power amp doing the work. This should not only increase the amount of sound out of the speakers, but keep the stock stereo lower in its range, yielding cleaner sound. The combinations of Polk speakers (400 series then) and an Alpine power amp worked great on my First Gen. It didn't have a CB so I used that space for the power amp. Todays amps are much bigger so it's become more of a problem to find a place to put one. Luckily the cassette has volunteered to live in the basement to make space for an amp. Now all I have to do is find one that fits.
rumboogy Posted February 25, 2010 Posted February 25, 2010 Just for curiosity sake...and from a lay person (so speak in beginners english)... How many channels How many Watts Maximum dimensions Power requirements Could you provide that information. Also..would the dimensions you provide be ONLY for the Cassette Deck bay or would you consider mounting in other locations? Also...would it be possible to connect the stock system directly to the amp and run the amp that way (see I told you I was a layperson). Thanks for any info...maybe if enough of us look...someone might find something. Wally
ken Posted February 26, 2010 Posted February 26, 2010 OK! fill me in here on whats wrong with the stock stereo other then the tape player. Granted it's been a few year since I sold my 05 Midnight but I remember being able to hear it just fine at any speed!
rumboogy Posted February 26, 2010 Posted February 26, 2010 Speaking for myself...I don't think there is anything actually "wrong" with it...however the sound is weak (I'm speaking of quality not loudness)....and a better set of speakers and a nice quality amp would make the sound more "pleasing" to listen to instead of hollow bass and treble we get now. Wally
Cougar Posted February 26, 2010 Posted February 26, 2010 I put a 4 channel 240 watt amp in my trunk a few years ago. http://www.venturerider.org/forum/showthread.php?t=487
Bummer Posted February 26, 2010 Posted February 26, 2010 The Polk 401s are rated for 135 watts peak, 4-45 RMS. I'm figuring when I do it I'll replace them all and wire the rears to actually be separate rather than bridged. So that would be 4 times 45 watts each at 4 ohms. I don't have any dimensions yet. That's going to have to wait a couple of weeks - gotta take the fairing apart before riding season and I'm going to take measurements then. I've done some browsing on Crutchfield (had very good luck buying from them a number of years back). I've found this, but obviously haven't tried it yet. Size should be very good. Power out is right. Thing is, it's not exactly aimed at what I'm planning on doing with it. Normally it's used to boost an existing Alpine in-dash unit. I planned to call Crutchfield and see what power level it's expecting for input. Shouldn't be a problem, but I thought I'd chat them up about it first. The whole point, to me, is first to replace the speakers, and second to add a little more volume while keeping the stock stereo running at a lower output level. If I can cut down my normal set point by say a third or half it'll really do a lot for the distortion levels. On my First Gen this type of change yielded much cleaner sound at roughly the same apparent volume levels in spite of the inherently bad acoustic environment on a bike.
