Godlover Posted February 24, 2010 #1 Posted February 24, 2010 Are Khrome Werks slip ons for a Harley Touring the same pipes for the Venture?
Seaking Posted February 24, 2010 #2 Posted February 24, 2010 Godlover said: Are Khrome Werks slip ons for a Harley Touring the same pipes for the Venture? Typically, anything that can fit on a Harley Road King etc will work on a Venture, if you have the plate adapter etc..
M61A1MECH Posted February 24, 2010 #3 Posted February 24, 2010 I can tell you that the Khrome Werks slipons that I purchased were listed as for the Venture and they were originally designed for a Harley, because along with the instructions for mounting them to a Venture they sent along instructions that at the top of the page for the installation instructions it states " 3" HP-PLUS MUFFLER W/MULTI-TIPS F/L85-94 & 95-98 FL & TOURING MODELS " The Venture kit does come with the adapter plates required to mount them to the Venture.
Godlover Posted February 24, 2010 Author #4 Posted February 24, 2010 Thanks - that's what I needed to know
Aimhigh Posted February 24, 2010 #5 Posted February 24, 2010 is the change out from stock to the Khromewerks pipes difficult?
SilvrT Posted February 24, 2010 #6 Posted February 24, 2010 Aimhigh said: is the change out from stock to the Khromewerks pipes difficult? It would be no more difficult than changing to Road King mufflers and that is a breeze.
M61A1MECH Posted February 24, 2010 #7 Posted February 24, 2010 Quote is the change out from stock to the Khromewerks pipes difficult? No it is a easy as pie, take the hanger bolts loose , the clamps loose slide oem mufflers off, assemble the Kromewerks hangers, bolt up attach clamps and fire it up.
GlennTuc Posted February 24, 2010 #8 Posted February 24, 2010 What would you need to get stock Road King pipes to fit a Second Gen?. Do they sound better than stock RSV pipes? Glenn
SilvrT Posted February 24, 2010 #9 Posted February 24, 2010 GlennTuc said: What would you need to get stock Road King pipes to fit a Second Gen?. Do they sound better than stock RSV pipes? Glenn Glenn, have you done a search on this site for Road King? There's ton's of info. To answer your question, they are a "slip on" fit. You will need a bracket for the rear mount and I'd recommend getting the V-Twin clamps. Info on all of this is in several places on the site. Yes, they do sound better IMHO. I have them and I've drilled out the baffles and I really love the sound and total cost to me was under $100 CAN.
YamaDuck Posted February 24, 2010 #10 Posted February 24, 2010 There are different Road King pipes. I have the RK slant cut pipes and they sound better IMHO. There is a member here somewhere that makes the bracket to mount them. Ebay has some chrome clamps for $36.
SilvrT Posted February 24, 2010 #11 Posted February 24, 2010 Here is a location for sound clips ... http://www.venturers.org/Tech_Library/?action=article&cat_id=002009&id=285
