Saddle_Bag Posted November 14, 2009 Posted November 14, 2009 I'm looking for an answer to a problem I'm having, and decided to go to the experts. I just completed a stator replacement. All went well, the second time. I don't want to explain. I am having an issue with the middle cover. After removing the allen screws, and removing the cover and gasket, something looked odd. On the back side, I expected a cylinder like backing on the bottom screw hole. To match up to the case with the gasket. (I have the copper washer) The top half of the cylinder is not there, and looks like it never was??? To put it simply, the dam thing won't stop dripping oil. It won't seal. I have never seen the back of this plate befoe, is there a piece missing or broken off. Any thoughts??? joe
MiCarl Posted November 14, 2009 Posted November 14, 2009 Are you talking about the dowel pins? There should be two of them, parts fiche isn't very clear on where they go. MKII service manual picture looks like the holes for them are at 4 o'clock and 8 o'clock. You can tell where they go by the larger holes in the gasket. That reminded me, I have a spare gasket and they are indeed at 4 and 8. There is no pin on the bottom hole, the one with the washer. Be aware that leaks at the grommets where the wires pass through the side cover look like they're coming from the middle gear cover. The oil runs down the wires and drips off the low spot - right behind the bottom of the middle gear cover.
Saddle_Bag Posted November 14, 2009 Author Posted November 14, 2009 No, I'm talking about the bottom one. The one with the copper washer. What is on the back . This is the one that seals to the middle gear cover. There is no flat spot on the back, it is a half circle and it won't seal with the engine. I think I really need a picture. I'll work on it. joe
dingy Posted November 15, 2009 Posted November 15, 2009 (edited) Pictures of area in question below. Hole just below top center is bottom hole of where middle drive cover bolts to. http://i1007.photobucket.com/albums/af193/gdingy101/midcoversmall.jpg front view of middle drive cover http://i1007.photobucket.com/albums/af193/gdingy101/midcoveroutersmall.jpg Back view of middle drive cover http://i1007.photobucket.com/albums/af193/gdingy101/Middlecoverinside.jpg Edited November 15, 2009 by dingy Revised caption on 1st picture
Ozlander Posted November 15, 2009 Posted November 15, 2009 Dingy, Now I am confused (happens every day). Your top picture show the bottom boss to be complete, like mine is. The bottom picture shows the upper half of the boss missing. Looks like that would be more apt to leak. Now I'm wondering how the oil drains when you take the screw out if the boss isn't cut away.
MiCarl Posted November 15, 2009 Posted November 15, 2009 Dingy, Now I am confused (happens every day). Your top picture show the bottom boss to be complete, like mine is. The bottom picture shows the upper half of the boss missing. Looks like that would be more apt to leak. Now I'm wondering how the oil drains when you take the screw out if the boss isn't cut away. Top picture is of the middle gear case, bottom is the cover. Oil gets through the little half moon cutaway on the cover to drain when you pull the bottom bolt. You can also see the larger diameter hole at the top left of Dingy's first picture. That is one of the dowel holes. The other one would be on the right, just above the top of the picture.
Ozlander Posted November 15, 2009 Posted November 15, 2009 I told you I was confused. I guess I've never looked at my cover close enough. I don't remember it being cut away, but it seems it would have to be.
dingy Posted November 15, 2009 Posted November 15, 2009 Sorry Oz, I revised caption on first picture to indicate it was of the case, not cover as I originally said. Dingy, Now I am confused (happens every day). Your top picture show the bottom boss to be complete, like mine is. The bottom picture shows the upper half of the boss missing. Looks like that would be more apt to leak. Now I'm wondering how the oil drains when you take the screw out if the boss isn't cut away.
Big Hack Posted November 15, 2009 Posted November 15, 2009 Did you get a new copper washer? I did when I replaced my pickup coil. the new washer is just a schmidge larger (od) it just would not seal. I fought a pesty leak untill I put the old washer back on and I used the oil resistant silicone on it, make sure everything is super clean (no oil residue) before using the silicone.
Saddle_Bag Posted November 15, 2009 Author Posted November 15, 2009 OK, It is called a boss? So having 1/2 of a boss allows the oil to drain. Why does the 1/2 boss seal? This is where I have a leak. I'm sooooo confused. After reading old posts , alot of us have leaks from this bolt , and a lot of wild tricks have been used to stop the flow. Thank You for the pictures. joe
Ozlander Posted November 16, 2009 Posted November 16, 2009 If I had a leak in that area, I would use some Permatex gasket sealer on both sides on the gasket in that area.
