i have nerve damage to left hand and significant strength loss as well. i would like the collective experience of you all help me decide the best course of action. let me preface by saying i really don't want an automatic clutch setup (at least not now). i can probably adjust the lever to where it actuates much closer to the grip, thereby reducing the length of stroke required to engage/disengage the clutch - does anyone see a drawback or potential long term problem with that? i know there is a ton of knowledge & experience in this group and i am counting on you guys & gals to get me back on my bike ......and thanks a ton in advance.
buz
hi buz
i have a 99 rsv i don't belive you can adjust the clutch lever on these bikes. maybe some one else will chime in with a better answer for you.
best reguards
don c.
You can buy a lever from another bike that is adjustable or an aftermarket that is adjustable. You might have to saw or grind off a tab and switch out the part that pivots to make it work , but it can be done.
tew47
The only Master Cylinder that i know of, which would fill your needs is a M/C from ISR Brakes. It's a swedish Company and those M/C's are designed to operate at first: adjusting the Lever/Force Ratio and second: adjusting the Lever Position to the Handle Bar.
There're NOT cheap, though. You can expect them to be in the 450 USD Area each.
http://www.isr-brakes.se/products/mastercylinders/21-012.shtml
or, operated with a external Reservoir this one ...
http://www.isr-brakes.se/products/mastercylinders/21-014.shtml
I have them on my '99 Max and i managed to get a Lot of them for my Vmax Buddies over here. Their Website is not up to date, but they have what you'll need, 17,5mm Piston Diameter for operating the Clutch Slave and available in both Handle Bar Diameters, 7/8"(1Gen) or 1 Inch(2Gen). You'll need one or even two hydraulic Switches to operate Starting the Bike in Gear and switching the Cruise Control if your Bike has this.
aussie annie,
i looked at their site and purchased a set of gloves - they are very reasobaly priced and have many great reviews. thank you very much for this info. when i am able to ride again i'll post how they worked out.
buz
Most Kawasakis have adjustable levers, and I know the new Voyager has a hydraulic clutch. Not sure if the lever would fit, or if you would have to change the whole reservoir. But you might check out several of the Kaws, one of the levers off their bikes might fit..
