Dragonslayer Posted July 1, 2009 Posted July 1, 2009 My friend has a Midnight Venture and recently had a carb repair at a local shop. Now the bike will crank and run on choke but as soon as he turns the choke off the carbs start dumping gas on the ground. I'm thinking float setting is wrong. If anyone has had similar problems please share.
Marcarl Posted July 1, 2009 Posted July 1, 2009 My guess would be float settings, unless the choke cable is routed wrong and causing problems,,,'course that is a wild shoot
