bmxndad Posted September 8, 2007 Share #1 Posted September 8, 2007 1999 RSV How does a guy make the rear blinkers act as another running light on these things? Thanks for any help. Ross Link to comment Share on other sites More sharing options...
High Plains Drifter Posted September 8, 2007 Share #2 Posted September 8, 2007 There are several good kits on the market. Check out Cruiser Customizing http://www.cruisercustomizing.com/ they have a couple to choose from and I've heard that Harley Davidson also makes a pretty good one. Jeff Link to comment Share on other sites More sharing options...
Gold Rush Posted September 8, 2007 Share #3 Posted September 8, 2007 http://www.thisoldtractor.com/gtbender/turn_signals_as_running_lights.htm#a_technique_using_one_single-element_bulb_in_each_turn_signal Here's a link to a site that might help you. Depending on where you live/ride you might want to re-think this idea. I didn't realize it was illegal to have amber lights on constant in the rear.....:whistling: Link to comment Share on other sites More sharing options...
High Plains Drifter Posted September 9, 2007 Share #4 Posted September 9, 2007 . . . Depending on where you live/ride you might want to re-think this idea. I didn't realize it was illegal to have amber lights on constant in the rear..... One of the kits that Cruiser Customizing sells is an LED set up that switches from red to amber and back. Ride Safe! Jeff Link to comment Share on other sites More sharing options...
Starrider04 Posted September 9, 2007 Share #5 Posted September 9, 2007 I have the red LED's that mount in the lens and still use the same bulb for the turn signals. Link to comment Share on other sites More sharing options...
MrRadi8 Posted September 9, 2007 Share #6 Posted September 9, 2007 1999 RSV How does a guy make the rear blinkers act as another running light on these things? Thanks for any help. Ross http://customdynamics.com/yamaha_turn_signal_retro.htm Dynamic clusters. Easy to wire in and replace and a hell of a lot brighter on the rear when combined with the LED taillight. Link to comment Share on other sites More sharing options...
Black Owl Posted September 9, 2007 Share #7 Posted September 9, 2007 Not sure what the 99 RSV has for rear turn signals. If they are using a lamp socket and 1156 lamp.... you can switch out the 1156 socket for an 1157 socket. As stated, not sure exactly what they are using, but switching from an 1156 to an 1157 lamp socket is a fairly simple process. You will need to solder a ground to the 1157 socket and splice into the tail light wiring (that should be the blue wire) to get constant power to the low illumination filament. If you run into no problemts you are looking at a 2 hour job and less than $15.00 in parts/wiring. Link to comment Share on other sites More sharing options...
Crash Posted September 9, 2007 Share #8 Posted September 9, 2007 I have had a KRISS module on my 2000 RSV and removed it and put it on my 05 RSV. Here's their site but this looks like a newer version. http://www.kriss.com/images/blank_a.jpg http://www.kriss.com/images/silver_b.jpg http://www.kriss.com/images/spacer.gif http://www.kriss.com/images/tab_nav.gif http://www.kriss.com/images/tab_brake_w.gif http://www.kriss.com/images/tab_modulator_w.gif http://www.kriss.com/images/tab_running_w.gif http://www.kriss.com/images/tab_elec_w.gif http://www.kriss.com/images/tab_lighting_w.gif http://www.kriss.com/images/tab_support_w.gif http://www.kriss.com/images/tab_home_a.gif http://www.kriss.com/gifs/placeorder.gif Select "Run Light" in navigation bar for more of these type items. http://www.kriss.com/gifs/mt.gif Products that work the first time & last a lifetime! Click here for http://www.kriss.com/gifs/questionmark.gif Detailed Information about this product Click for price of this unit. Please set you browser to allow animations for viewing http://www.kriss.com/gifs/panther.jpg PANTHER SERIES RUNNING & BRAKE UNIT for rear turn signals Nothing compares to the brilliance and visibility of this system when you use the brakes. See list of all functions in description details on info page. Demonstration changes operation with Brake use. (optional Running Light operation shown On) http://www.kriss.com/gifs/vtxr1.gif http://www.kriss.com/gifs/vtxr2.gif http://www.kriss.com/gifs/vtxr4.gif http://www.kriss.com/gifs/vtxr3.gif http://www.kriss.com/gifs/mouse.jpg For demonstration only steady flash is shown) (Does not flash the stock red brake light) http://www.kriss.com/gifs/dot-line.jpg Optional Wigwag with Brakes. (running lights not selected) http://www.kriss.com/gifs/vtxr1.gif http://www.kriss.com/gifs/vtxr2.gif http://www.kriss.com/gifs/vtxrb4.gif http://www.kriss.com/gifs/vtxr3.gif http://www.kriss.com/gifs/check-blk.gifPart #RL5000 http://www.kriss.com/gifs/rollback_119.jpg We've reduced the need to raise prices, even with copper wire increases of 50%. http://www.kriss.com/gifs/whiteblank.gif Improved utilization of our resources and streamlined operations is allowing us to offer what the customer wants. © Kriss 1986-2007 all rights reserved Brake Light Flasher Brake Light Flasher Trunk Light Flasher Trunk Light Flasher Gold Wing Trunk Flasher Gold Wing Trunk Flasher GL1800 Spoiler Flasher GL1800 Spoiler Flasher Running/Brake for signals Running/Brake for signals Identifying kinds of bulbs Identifying kinds of bulbs Harley-Davidson Modulator - plug & play Harley-Davidson Modulator - plug & play High Beam (H4) Modulator - plug & play High Beam (H4) Modulator - plug & play High & Low (Single bulb) (H4) Modulator - plug & play High & Low (Single bulb) (H4) Modulator - plug & play Dual bulb (2-H4) Modulator - plug & play Dual bulb (2-H4) Modulator - plug & play H(x)(H1,H3,H7,etc.) High Bulb Modulator H(x)(H1,H3,H7,etc.) High Bulb Modulator H(x)(2-H7,etc.) Dual High Bulb Double Eagle Modulator H(x)(2-H7,etc.) Dual High Bulb Double Eagle Modulator Illuminator H(x) - Makes high work like a low beam Illuminator H(x) - Makes high work like a low beam GL800 High beam Modulator GL800 High beam Modulator GL1800 Integrated High & Low Modulator GL1800 Integrated High & Low Modulator Value priced Single Bulb Modulator Value priced Single Bulb Modulator Value priced Dual Bulb Modulator Value priced Dual Bulb Modulator The LAW (Modulator Regulations) The LAW (Modulator Regulations) Running/Brake light unit for rear signals Running/Brake light unit for rear signals Scooters-Running/Brake light unit for rear signals Scooters-Running/Brake light unit for rear signals Hazard Flasher for signals Hazard Flasher for signals Turn Signal Cancellation Unit Turn Signal Cancellation Unit 'BLT' Brake light/Signal Running System 'BLT' Brake light/Signal Running System 'TBM' Brake light & Signal Communicator 'TBM' Brake light & Signal Communicator 'RLH' Signals-Running/Brake/4-way Hazard 'RLH' Signals-Running/Brake/4-way Hazard Trailer Power Isolator Trailer Power Isolator for Side Car use for Side Car use for Accessory use for Accessory use Driving Light Controller Driving Light Controller Police Interceptor Police Interceptor for Events & Parades for Events & Parades Technical Support Index Technical Support Index Home Page Home Page Ordering Information Ordering Information Warranty & other info Warranty & other info Products listed in a table Products listed in a table Price list Price list Link to comment Share on other sites More sharing options...
High Plains Drifter Posted September 10, 2007 Share #9 Posted September 10, 2007 I have had a KRISS module on my 2000 RSV and removed it and put it on my 05 RSV. Here's their site but this looks like a newer version. This is a neat system as are some of the others listed here. However, after doing some checking, GOLD RUSH is right. In most states it's illegal to run amber run or brake lights (on the rear of a bike) and illegal to run red turn signals on newer model bikes. Read carefully the description on these light kits and make sure that they comply with your local laws. One of the kits listed here has a disclaimer in their discription that says they are only legal for "show and off-road use." That wouldn't do much good on my bike! Ride safe! Drifter Link to comment Share on other sites More sharing options...
concours Posted September 10, 2007 Share #10 Posted September 10, 2007 I have the turn signal conversion kit from here... http://www.electricalconnection.com/ which retains the amber bulb for turn sig, but adds a ring of RED LED's at HALF brightness for running lights, and also changes to VERY BRIGHT RED LED's for auxiliary stop lights as well. I recommend it highly. I've always used the SOS Priority Lights in the past but this rocks way better. All trying to stay alive in Boston traffic at rush hour. Link to comment Share on other sites More sharing options...
