LtShame Posted June 7, 2009 #1 Posted June 7, 2009 How easy is it to remove the seat on a 2003 venture...i want to run my wires for my led's under there?
flb_78 Posted June 7, 2009 #2 Posted June 7, 2009 It's very easy. There are 2 nuts underneath the front end. You can either use a 10mm open/box end wrench or a 5mm allen wrench to remove the nuts. Be very careful tightening them back off. Several have had the bolt either pull out of the seat or break off. They just need to be snug.
1BigDog Posted June 8, 2009 #3 Posted June 8, 2009 You might want to look in the classifieds to see if Rick Butler still makes the thumbscrew seat nuts. Makes removal and installation so much easier. You dont know what youre missing unless you have a set of Ricks nuts on your seat.
Mariner Fan Posted June 8, 2009 #4 Posted June 8, 2009 Ruffy said: You might want to look in the classifieds to see if Rick Butler still makes the thumbscrew seat nuts. Makes removal and installation so much easier. You dont know what youre missing unless you have a set of Ricks nuts on your seat. http://www.m109riders.com/forums/images/smilies/shocked.gif
Bobby G Posted June 10, 2009 #7 Posted June 10, 2009 How exactly does one go about acquiring Rick's nuts?
1BigDog Posted June 10, 2009 #9 Posted June 10, 2009 Bobby G said: How exactly does one go about acquiring Rick's nuts? http://www.venturerider.org/classifieds/showproduct.php/product/1663/cat/7/date/1161840513 Here ya go..........and only 5 bucks to boot!!! (with apologies to rick)
