ventureohio Posted May 30, 2009 Share #1 Posted May 30, 2009 Hello Venture Riders. I need some help. I have looked in the service manual and cannot find the fix for this. I have a First Generation 1985 Venture Royale, 1200cc. My shift indicator only works in 4th and 5th gear. The display never drops below 4th gear. Is there an adjustment that I can do on this? If so where is it on the gear case or motor? Thanks in advance. Link to comment Share on other sites More sharing options...
GeorgeS Posted May 30, 2009 Share #2 Posted May 30, 2009 There is a Rotary Switch, located under the AFT, Case cover on left side of CrankCase. Shaft comes thru sidewall, of lower crankcase. This is a 6 position switch, 1 thru 5 and neutral. 6 wires from switch, run up to the Indicator ( CMS Unit ) Switch, applies electrical ground, to " One of the Wires " for whatever gear you are in. The Switches, are Notorious for going bad. To get access, you have to pull OFF the AFT left side cover. ( sorry ) ( New Gaskets needed ) Now follow the cable from the switch, to a Pull Apart Electrical Plug. Open Plug, and apply a " TEST " ground, to each of the 6 pins going up to the CMS. As you do this, the Indiator will change numbers. If you get 1 thru 5, plus N. Then the Indicator is Good, and the Switch is bad. To fix switch, Remove it, and Apply, a light coating of Solder to each of the contacts, and they will start makeing good contact again. Link to comment Share on other sites More sharing options...
Squeeze Posted May 30, 2009 Share #3 Posted May 30, 2009 Don't forget the copper Washer on the lowest of the six Bolts of the Cover. Link to comment Share on other sites More sharing options...
friesman Posted May 30, 2009 Share #4 Posted May 30, 2009 Don't forget the copper Washer on the lowest of the six Bolts of the Cover. Squeeze, i dont recall a copper washer on mine. what is it for? Brian Link to comment Share on other sites More sharing options...
Squeeze Posted May 30, 2009 Share #5 Posted May 30, 2009 The inner Engine Casting around the Trans doesn't allow all oil to flow back to the Oil Pan. So there's always around 0.2 Liter Oil trapped. The lowest of the six Bolts is the Drain Bolt for that Area and needs to have a Copper Washer to seal. Otherwise it can leak there. Doesn't mean it WILL leak, but it can. Yammi says there should be a Copper Washer. I learned it the leaky Way. Link to comment Share on other sites More sharing options...
Yammer Dan Posted May 30, 2009 Share #6 Posted May 30, 2009 The inner Engine Casting around the Trans doesn't allow all oil to flow back to the Oil Pan. So there's always around 0.2 Liter Oil trapped. The lowest of the six Bolts is the Drain Bolt for that Area and needs to have a Copper Washer to seal. Otherwise it can leak there. Doesn't mean it WILL leak, but it can. Yammi says there should be a Copper Washer. I learned it the leaky Way. Thats the way I learned that one!! Don't forget when you learn like that. Link to comment Share on other sites More sharing options...
ventureohio Posted May 30, 2009 Author Share #7 Posted May 30, 2009 As soon as I can turn a wrench again, (just had Carpal Tunnel Surgery) I will get in there and let you know what I found. Thanks for the help, Hopefully I can pay it forward some day. Link to comment Share on other sites More sharing options...
