Reed Posted April 27, 2009 #1 Posted April 27, 2009 Has any one tryed Dyna beads in there tires for balancing? I read the post that some were trying it but not much info was there. 1000 miles or less. has any one used it for the life of a tire & how did it work? would you use it again?
slick97spirit Posted April 27, 2009 #2 Posted April 27, 2009 I just purchased enough for my front tire and my trailer tires. Haven't installed them yet. I'm hoping they work well.
Guest BluesLover Posted April 27, 2009 #3 Posted April 27, 2009 A buddy used them on his Gold Wing last year. Claims that he got longer wear from the new tire because of them. I'm going to try them the next time I have to replace rubber on the bike. Cheers,
TheKid Posted April 27, 2009 #4 Posted April 27, 2009 I am using them in my tires on the bike and it is the best balance i have ever had on any bike. I can comfortably take my hands of the handle bars and there is no wobble at all. I also have taken the rotor covers off and I know there was a weight on one of them as well and i can not tell any difference in riding. I really like them because they can't fall off and allow the tire to get out of balance, also if you pic up a rock or anything to change the balance they will move to re balance the tire. They can be used over and over as well.
RedRocket Posted April 28, 2009 #5 Posted April 28, 2009 I tried them on my VFR and didn't think it was any better or worse than my own balancing job.
Wanderer Posted April 28, 2009 #6 Posted April 28, 2009 Been using them for the last two years. For my money the best way to balance a tire. Longer wear and smoother ride with any tire. When I change my tires I won't do any thing else.
wild hair 39 Posted April 28, 2009 #7 Posted April 28, 2009 do they work with RIDE-ON,last time i tryed sume beeds,when i changed the tire,there was no beeds in the tire,the RIDE-ON,worked thro
Wanderer Posted April 28, 2009 #8 Posted April 28, 2009 wild hair 39 said: do they work with RIDE-ON,last time i tryed sume beeds,when i changed the tire,there was no beeds in the tire,the RIDE-ON,worked thro The web site suggests you not use them with Ride-on, Slime, or etc.
slick97spirit Posted April 28, 2009 #9 Posted April 28, 2009 They will not work with Ride on or any other flat tire fixer, etc. The beads need to be able to roll around on the inside of the tire.
Midrsv Posted April 28, 2009 #10 Posted April 28, 2009 I was told by a local shop that you couldn't use the beads in a wheel that had a 90 degree valvle stem like our rears. Is that true? I couldn't see what difference it would make. I am seriously thinking about trying them. DT
Wanderer Posted April 29, 2009 #11 Posted April 29, 2009 Midrsv said: I was told by a local shop that you couldn't use the beads in a wheel that had a 90 degree valvle stem like our rears. Is that true? I couldn't see what difference it would make. I am seriously thinking about trying them. DT Valve stem has nothing to do with it. It is slightly harder to put beads in a 90 degree valve, but i just keep tapping on the stem with a screw driver as the beads flow in. No problem really.
Roy Hoffman Posted April 29, 2009 #12 Posted April 29, 2009 I put in Dyna Beads 9k miles ago when I put the Avon Venoms on. The wear is showing no uneveness at all and there is no wobble or bounce. I would use them again and a few friends went to them when they saw my tires.
eusa1 Posted April 29, 2009 #13 Posted April 29, 2009 the beads can be used with the 90% stem. use a engraving tool or a vibrating device against the stem when installing. they seem to do a fine job in my bikes. mike
slick97spirit Posted April 29, 2009 #15 Posted April 29, 2009 Midrsv said: I was told by a local shop that you couldn't use the beads in a wheel that had a 90 degree valvle stem like our rears. Is that true? I couldn't see what difference it would make. I am seriously thinking about trying them. DT the valve stem has to have enough room for the filtered valves they provide on their site. The filtered valves keep the beads from coming out of the stem when checking tire pressure, etc. I just put them in my trailer tires. The trailer tires require 1oz. each. The front/rear tires on a 2nd gen. needs 2 oz. I put a vibrating sander against the valve stem to get them to flow into it.
Midrsv Posted April 29, 2009 #16 Posted April 29, 2009 Wanderer said: Valve stem has nothing to do with it. It is slightly harder to put beads in a 90 degree valve, but i just keep tapping on the stem with a screw driver as the beads flow in. No problem really. Can they be put in with the wheel on the bike or does it have to be removed and place horizontally? DT
slick97spirit Posted April 29, 2009 #17 Posted April 29, 2009 as long as you can access the valve stem they can go in. You have to totally deflate the tire by remove the old valve, put the beads in, then replace the valve with the filtered one. Takes about 5 minutes per tire.
Sunman Posted April 29, 2009 #18 Posted April 29, 2009 I am surprised, that this has 2 pages, and no one has posted a link to the site yet? Or any resources to buy this product? Somebody is slipping . If you are putting them in with a new tire, could you not just toss the beads in before mounting? Or do you have to add them through a valve stem for some reason? Sounds like a property of physics that this product uses, to find the lightest spot on the tire. Do these beads balance the tires by themselves, or just supplement regular lead weight balances?
brewser23 Posted April 29, 2009 #19 Posted April 29, 2009 Ask and ye shall receive....here it is http://www.innovativebalancing.com/index.html, do a dealer search, couple in the Toronto area. Product seems to perform as advertised. Valve stem method is probably used due to the beads being very small. I would think that you would stand a good chance of losing a lot of them when you were seating the bead. Not that difficult to do and and engraving tool vibrating agains the valve stem helps to keep them moving, tube clogs up pretty quick without it.
Rocket Posted April 29, 2009 #20 Posted April 29, 2009 brewser23 said: Ask and ye shall receive.... Here is the link to their CDN site http://dynabeads.3dcartstores.com/
Reaney in NH Posted April 29, 2009 #21 Posted April 29, 2009 I have never used them in my bike... but I plan to on the next tire change. But, I would like to add this. I have a Suzuki Samurai with 35" Tires. Tires that large are hard to balance correctly and my constant use off road would knock off the wheel wieghts. I added Dyna beads 2 years ago and never looked back. They work AWESOME. I still don't understand the physics of it... but I can't argue with success.. they work.
Midrsv Posted April 29, 2009 #22 Posted April 29, 2009 Fromt the table on the web site it appears that you would need to use 2 oz per wheel. Is that correct? I have a daler near me and I plan to install some this weekend. DT
Wanderer Posted April 29, 2009 #23 Posted April 29, 2009 Midrsv said: Fromt the table on the web site it appears that you would need to use 2 oz per wheel. Is that correct? I have a daler near me and I plan to install some this weekend. DT 2oz per tire seems right. I think that's what I was using on the voyager
Reed Posted April 29, 2009 Author #24 Posted April 29, 2009 Go to the web sit. there is a chart that tells how much to put in any size tire. most ventures take 2 oz. ber tire. pickup tires 5oz. big truck 16oz. some have used 2 lbs in pulling trucks. take your pick. I just ordered 4oz.for my bike & 20 oz for my pickup. will see if it helps?????? Thanks for info. MORE LATER on what I find out. Dyna Beads
Midrsv Posted April 30, 2009 #25 Posted April 30, 2009 I just installed 2 oz in each tire tonight and I rode a couple of miles down the road. At 70 mph I pulled the clutch and let it coast and the bike was perfectly smooth. Initial impressions are that this is good modification. Dennis
