Cougar Posted April 11, 2009 Share #1 Posted April 11, 2009 Wow , what a great ride today on my new trike. My First ride my Cruise Control was kinda acting kinda funny. ride for a while then it would just go off I could re-set it.. ride for a while and it would go off. Now , today I turn everything on and I hit SET and the lights just keep blinking then go off. then come back on as if it were still trying to set itself again.. (never did lock in place) Now after saying that .. the front of the bike had the 6 deg rake kit added to the bike at my dealers. Worked fine before it went into surgery. so what do you folks think they might of messed up or did not put back on right , before I go and dig into this after my NAP ! this afternoon! Dealer is 70 miles away , I would have to take time off work and I really want to just fix there mistake myself if I can. I sure will let them know what you guys came up with for the fix though! Thanks for any in-put gang! Jeff Link to comment Share on other sites More sharing options...
Carbon_One Posted April 11, 2009 Share #2 Posted April 11, 2009 I would start with checking all the electrical connections for the cruise section. Perhaps one of the quick connectors isn't fully inserted thus getting intermitment electrical flow for the unit. You'll probably have to pull the front fairing off and maybe even both lower cowlings. Left cowling has the vacumn controler mounted by the horn and the right side cowling has the servor unit & fuses I believe. Good luck Larry Link to comment Share on other sites More sharing options...
Cougar Posted April 11, 2009 Author Share #3 Posted April 11, 2009 Ohhh Great Larry, Remove the lower fairing right after a nap? Your Kidding Right? Ok, Will go out now and look around. Is it hard to remove the lower fairing? My Computer is on in the garage. Thanks, Jeff Link to comment Share on other sites More sharing options...
Cougar Posted April 11, 2009 Author Share #4 Posted April 11, 2009 Found that the two metal cable supports are loose that come out of the switch housing.. are they supposed to not wiggle? Link to comment Share on other sites More sharing options...
HGWT Posted April 13, 2009 Share #5 Posted April 13, 2009 I would check the space between the speedo pickup and the gear. Every year I have readjust the space on my trike. Link to comment Share on other sites More sharing options...
Cougar Posted April 13, 2009 Author Share #6 Posted April 13, 2009 Darrell, long time no see my friend! ~S~ Hey I know were the speedo pick-up is (on the drive) but the (gear) ? Jeff Link to comment Share on other sites More sharing options...
