jonn1963 Posted April 9, 2009 Posted April 9, 2009 New member here. I'm needing to find a mech. around Logan Ohio that can get my carbs right. I've owned the bike since last May. When I first got it it was low on power so I took it to a mechanic but it was worse. Took it to another shop and the bike still wasn't right. Took it to an old school shop and it ran much better but still seemed low on power and would shake under load, but after 3 shops I drove it like it was and the bike served me well. 20,000 mile later it had less power and the fuel mileage dropped. I called around but noone seemed to be interested in working on it so I made a manometer and tried to sync them myself but made it worse. Can someone suggest a good mechanic or fellow venture owner that has a carbtune and knows how to adjust in my area. It's an 1983
BuckShot Posted April 9, 2009 Posted April 9, 2009 Freebirds maintenace day--June 6--Oberlin, Ohio. Sorry I couldn't be more help. You may have to trailer it there if worse comes to worse. Maybe someone will chime in that can help you more.
Dano Posted April 9, 2009 Posted April 9, 2009 Have you pulled the side covers off the carbs and checked the diaphragms? Sounds like that may be a majority of your problem. You can download a service manual here, just go under "Forums" then 1st gen technical library. Hope you got DSL or cable internet. It's a pretty big file. You've got some guys over in WVa that might be close to you. There's a thread on here about ordering new diaphragms that would be of benefit to you. Good luck and ask more questions and we can help you do this yourself! Dan PS Welcome to the site!
jonn1963 Posted April 9, 2009 Author Posted April 9, 2009 I have the manual but haven't pulled the side covers. I can tell you that when I adjust the jets on 1 and 2 there is no change at all in RPMs, and when I pulled the cap on the number 2 carb to check vacume a little gas trickled from it. Not sure if thats normal. Going to Deals Gap to ride the Dragon next week, guess I'll be riding my GS850. The suzuki"s alot more fun in the curves but I sure am going to miss that fairing with the chilly temps.
ChurchBuilder Posted April 10, 2009 Posted April 10, 2009 Have you tried running a can of "Seafoam" through it? I run some through each season and mine runs good.
jonn1963 Posted April 10, 2009 Author Posted April 10, 2009 I run seafoam thru it every few months. Late October till March I call Jacksonville Fl home so its allways riding season for me. For New Years I put at least 1500 miles on it during a 4 day trip to the Keys. Always brand name gas like BP or Texaco and always the highest octane they have. Keep track of mileage every tank, something I do with all my vehicles. I should tell you that I am a full-time RVer so I dont have a garage or closed in area to work on it. I do most of my own work and I would buy Morgan Carbtune and rebuild them myself but I'm afraid of things being exposed to the elements.
rhncue Posted April 10, 2009 Posted April 10, 2009 My 83 has not been inside of a garage since it left the showroom floor. What's to be afraid of? They are each fairly simple devices. You just have 4 of them so it looks complicated. You can rebuild them in an afternoon. I would try to acquire another set of carbs just for spare parts in case any are needed such as floats, needle valves or diaphragms. Get a gallon can of carb cleaner to soak the parts in and go at it one carb at a time. I do one at a time so as not to mix parts between carbs. Don't soak any rubber parts. Dick
