dfitzbiz Posted March 26, 2009 Posted March 26, 2009 The head gasket on my '99 RSV is leaking anti-freeze from the front left corner where the cylinder block meets the crankcase. I removed the cooling fin to confirm this. This only happens when the engine is cold and it appears to seal up when the engine warms up. Can anyone tell me if you can change the head gasket with out removing the engine? Can the head bolts be re-torqued by removing the cylinder head covers? Any assistance will be appreciated. Fitz
pegscraper Posted March 26, 2009 Posted March 26, 2009 Sorry, you'll have to pull the engine to remove the head. The bolts are long, and there's nowhere near enough room in the frame to lift the head up over the top of them. You might try just retorquing the bolts. You'll have to remove the cam covers and also the cams. The head bolts are underneath the camshafts. It's a lot of work, but least this can be done without pulling the engine out.
BradT Posted March 26, 2009 Posted March 26, 2009 You sure it is the head gasket ? I remember reading here about the rubber plugs on the side of the block leaking when cold. I think the solution was to tape a washer to the inside of the Fake fins, where it pushes against the Rubber plug. Other than that then Pegscraper has the info right on. Brad
SilvrT Posted March 26, 2009 Posted March 26, 2009 You might want to look into a product called "Thermagasket" Check my thread at ... http://www.venturerider.org/forum/showthread.php?t=18744&highlight=dakota It's been over a year now since I installed that product and still no more head gasket leakage on my Dakota... nor do I have any cooling / cooling system issues.
dfitzbiz Posted March 26, 2009 Author Posted March 26, 2009 Thanks to all for the input. I believe I will try the re-torque route first. Fitz
tazmocycle Posted March 28, 2009 Posted March 28, 2009 how many miles and how long have you had it. there was some ventures that had loose head bolts from factory. i agree with you to try and re-tourqe the head bolts first before pulling motor. good luck!!
