6pak Posted July 8, 2007 Share #1 Posted July 8, 2007 Here we go again. We now have a new clutch, new slave, plenty of pull on the handle, no air in the lines, clear return hole, scuffed the metal plates, and still the thing slips. The only thing that isn't new on the thing is the pressure plate. The only positive is that it doesn't seem to slip quite as bad. Now I'm wondering, would it help if I replaced a couple of the (cork) plates with steel ones? Or do I go with an aftermarket clutch spring? As I'm at a complete loss of ideas, how about some more of that advice? Link to comment Share on other sites More sharing options...
Yammer Dan Posted July 8, 2007 Share #2 Posted July 8, 2007 Did you replace the Spring? Link to comment Share on other sites More sharing options...
6pak Posted July 8, 2007 Author Share #3 Posted July 8, 2007 plates(cork and steel), clutch boss, clutch spring, slave cylinder,prestone dot3 in hydraulics, yamalube 20-40 in motor. Link to comment Share on other sites More sharing options...
Marcarl Posted July 8, 2007 Share #4 Posted July 8, 2007 You need to have a weee bit of play on the handle when it's released, do you have that? This is starting to really drive me bonkers. How much tourque on the clutch springs? Did you line up the clutch plates properly? Maybe somebody put in the wrong size push rod, so maybe check that out, pull the cover and make sure it returns all the way and allows the clutch to come together completey. I'm gone all day, 'see' you tonight. Link to comment Share on other sites More sharing options...
okscooter Posted July 8, 2007 Share #5 Posted July 8, 2007 Bite the bullet and install your clutch the PCW Racing Vmax way. Get their heavy duty clutch spring, throw out the half size diameter friction disc, the small steel ring that's supposed to go inside that half size friction disc, the cheesy long wire that holds those two parts in, and replace that half size friction disc with another full size one. Your actually removing the (clutch damper) and replacing these part with one full size clutch (fiber) plate. follow the PCW instructions. This make a bullet proof clutch, its what I did. Make sure you install the fiber (cork) plates correctly, read manual or read here: http://vmax.lvlhead.com/tips/clutch.htm This guy is actually doubling up 2 clutch diaphram springs here. Call John, tell him what you've done so far, he'll walk you thru it. http://www.pcwracing.net/featured.htm Link to comment Share on other sites More sharing options...
Yammer Dan Posted July 9, 2007 Share #6 Posted July 9, 2007 Sure about notches on plates ans Spring plate? Got to be some little thing. Link to comment Share on other sites More sharing options...
MILLMAN37 Posted July 9, 2007 Share #7 Posted July 9, 2007 CHECK OUT j&P CYCLE. THEY HAVE THE CLUTCH SPRING CONVERSION FOR THE VENTURE $126 (PURPLE) THE LAST TIME I CHECKED. Link to comment Share on other sites More sharing options...
Gearhead Posted July 9, 2007 Share #8 Posted July 9, 2007 OKScooter or anyone who knows, what is the deal with the clutch damper? It literally just consists of a half thickness disk, ring and retaining wire? What is its purpose? What is the trade-off of removing it? Jeremy Link to comment Share on other sites More sharing options...
Denden Posted July 9, 2007 Share #9 Posted July 9, 2007 OKScooter or anyone who knows, what is the deal with the clutch damper? It literally just consists of a half thickness disk, ring and retaining wire? What is its purpose? What is the trade-off of removing it? Jeremy it's purpose is to make clutch engagement smoother. An anti-chatter clutch. It provides a small amount of slipping at the point of engagement. I removed mine long ago (on my '83), replaced those parts with full size clutch plates, did away with the wire that separated the thinner plates from the rest of the plates. I never noticed any difference. Link to comment Share on other sites More sharing options...
Gearhead Posted July 9, 2007 Share #10 Posted July 9, 2007 Thanks. I asked the trade-off of removing it, now, what is the benefit of removing it? Is is a known common cause of slippage? Thanks again, Jeremy Link to comment Share on other sites More sharing options...
Denden Posted July 10, 2007 Share #11 Posted July 10, 2007 Thanks. I asked the trade-off of removing it, now, what is the benefit of removing it? Is is a known common cause of slippage? Thanks again, Jeremy It's not a common cause of slippage. As long as the clutch plates and springs are in good condition, the stock clutch (with the anti-chatter) works just fine. It gets removed by gearheads like me who want to go a little faster, put more power to the ground, lift the front wheel...basically, it's sort of a hot-rod thing to remove it. Some people just like to tinker. Link to comment Share on other sites More sharing options...
Gearhead Posted July 10, 2007 Share #12 Posted July 10, 2007 Is it believed that removing the anti-chatter and replacing with a regular disk makes the clutch "stouter", that is, able to handle more power? Thanks for tolerating my persistent questions. Jeremy Link to comment Share on other sites More sharing options...
Denden Posted July 10, 2007 Share #13 Posted July 10, 2007 Is it believed that removing the anti-chatter and replacing with a regular disk makes the clutch "stouter", that is, able to handle more power? Thanks for tolerating my persistent questions. Jeremy Yes, a little "stouter", but more important to racers, more controlable by the rider. An experienced drag racer wants to be able to control the amount of clutch slip himsself for a good hard launch. The anti-chatter feature of the clutch is so that inexperienced riders can take off smoothly, without the bike "bucking". An experienced rider doesn't need that feature, can feel what the clutch is doing. Also without the anti-chatter, the clutch will "grab" exactly when the racer wants it to hook up. AND it makes showing off by lifting the front wheel a lot easier...lift the front wheel hitting second gear, too. Or if you do it right, light up the rear tire and paint a black line on the pavement. (But I don't do that anymore:whistling:) Link to comment Share on other sites More sharing options...
Yammer Dan Posted July 10, 2007 Share #14 Posted July 10, 2007 Yes, a little "stouter", but more important to racers, more controlable by the rider. An experienced drag racer wants to be able to control the amount of clutch slip himsself for a good hard launch. The anti-chatter feature of the clutch is so that inexperienced riders can take off smoothly, without the bike "bucking". An experienced rider doesn't need that feature, can feel what the clutch is doing. Also without the anti-chatter, the clutch will "grab" exactly when the racer wants it to hook up. AND it makes showing off by lifting the front wheel a lot easier...lift the front wheel hitting second gear, too. Or if you do it right, light up the rear tire and paint a black line on the pavement. (But I don't do that anymore:whistling:) Now that could get a few comments. But I won't say Nothing...:stirthepot: Link to comment Share on other sites More sharing options...
Denden Posted July 10, 2007 Share #15 Posted July 10, 2007 Now that could get a few comments. But I won't say Nothing...:stirthepot: Why? How long did you say your last rear tire lasted? Link to comment Share on other sites More sharing options...
pappyam Posted July 10, 2007 Share #16 Posted July 10, 2007 I put in a Barnett when I got the Venture and it still slipped. I dont remember if I did any other mods to the clutch but I did double up the spring and that solved the problem. Don Link to comment Share on other sites More sharing options...
